Please Help With Vibration Problem
  • Thread starter Thread starter erniet17
  • Start date Start date May 16, 2008
erniet17
124
May 16, 2008
  • May 16, 2008
Hey all. I recently swapped my tranny out for a T-5. Before my swap I had vibration at about 80-85 MPH and then it would settle a bit.The car starts to vibrate at about 80 MPH and dies down a bit after 85 or 90 MPH. Kind of the same thing as before. I replaced the driveshaft for a new aluminum Ford driveshaft, re-balanced the wheels, replaced the gears for 3.73 and replaced the harmonic balancer. The driveshaft tamed it down a bit. Any idea on what this could be? I don't know what else to change/check out. Thank you all in advance.
erniet17
124
May 19, 2008
  • May 19, 2008
Wow! No replies???
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
May 19, 2008
  • May 19, 2008
have you changed suspension, is your pinion angle correct
erniet17
124
May 19, 2008
  • May 19, 2008
The suspension is stock at this time. I am going to replace the shocks and struts soon. I would think that if it was the suspension that I would feel it throughout the whole car. There is some vibe throught the car but most is on the shifter. How do I go about checking the pinion angle?
skunk21
1,203
Taxachusetts
May 19, 2008
  • May 19, 2008
Like S&B states you want check the angle. you want the angle of the drive shaft in relation to the rear end to be as straight has possible. when you look under the car the drive shaft should close to straight it won't be prefect. If the front of the shaft coming out of tranny pitches down and the rear pitches up the tail of tranny is up high(since the car is on stock suspenion the pumpking shouldn't have moved) I would check for worn motor mounts which will cause the motor to drop. you can look at your fan and see if has worn at the tips from rubbing on the fan shroud or is real close to the bottom of the shroud vs the top, also they will be dry rotted pretty bad and look collapsed. If it's the opposite the tranny mount maybe bad. most of the time it's worn motor mounts causing an issue. a bad pinion angle can cause binding and wear out the u-joints and I'm sure cause a vibration. that's a starting point anyways.
1987stangman
684
24
  • May 19, 2008
He did say that the car vibrated before the gear and tranny swap so pinion angle couldn't be it if he was running a stock rear and trans before unless he reused a drive shaft with bad U-joints. I had a vibration issue RIGHT after I installed my 3:55's. I did the install myself but was 100% sure of my work so I looked elsewhere. I had the tires balanced first but problem not solved and I already had an aluminum drive shaft. Vibration at the exact same speed and just when I started to doubt my work I noticed there was a odd deformaty in my right front tire. I had it check and sure enough it was bad. Once a new tire was installed vibration gone.
Front wheel bearings, bad suspension bushings, including rack bushings can all cause bad vibration including the previously mentioned motor & tranny mounts.
erniet17
124
May 19, 2008
  • May 19, 2008
The motor mounts and transmission mount were replaced last month. I am going to take it to a guy that has been working on these cars for about 20 years. Maybe he can figure it out. The problem is that in Miami it is hard to maintain 80+ MPH due to all the traffic. Maybe he can look at the pinion angle and tell me what he thinks. I'll update the post when I find something out.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
U
8 Years of Vibration leading to engine knock?
  • UpgradeXP
  • Apr 14, 2025
SN95 V6 Mustang Tech Apr 14, 2025
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
