PLEASE HELP
  • Thread starter Thread starter b1gp1mp1n247
  • Start date Start date Apr 1, 2004
b1gp1mp1n247
159
Pittsbrugh, PA
Apr 1, 2004
  • Apr 1, 2004
i am getting 10-11 miles per gallon. i know that is extremely low. please help i have tried everything. also the car idles way too high, and is hard to start when motor is cold. please help. im open to anything.
HISSIN50
34
129
Apr 2, 2004
  • Apr 2, 2004
have you pulled codes? even if the CEL is not on, codes can be stored in KAM.
i would really look at a couple of things, given that im shooting in the dark here. check voltage/resistance outputs for the O2's, as well as the ECT and ACT sensors.
those are the big ones i can think of. did you idle go up when you lost milage, or was it like that before?
good luck.
b1gp1mp1n247
159
Pittsbrugh, PA
Apr 2, 2004
  • Apr 2, 2004
good luck.
it all pretty much happened at the same time. my idle started to get real ****ty and my gas mileage went down the ****ter with it. O2's are new. ect and act are not ill try that
HaggardGT
59
Tolland, CT
Apr 2, 2004
  • Apr 2, 2004
Did you check what your fuel pressure is at? I've seen pressure regulators crap out on people before, unfortunately it DOES happen.
b1gp1mp1n247
159
Pittsbrugh, PA
Apr 2, 2004
  • Apr 2, 2004
regulator is new. its at 40psi
b1gp1mp1n247
159
Pittsbrugh, PA
Apr 2, 2004
  • Apr 2, 2004
any lower and it runs like complete A55
HaggardGT
59
Tolland, CT
Apr 2, 2004
  • Apr 2, 2004
Really? That's unusual. A friend of mine just went to the dyno with his '93 Cobra. He put the pressure back to stock from 38 or 39 and picked up 16 horses. Wierd.
b1gp1mp1n247
159
Pittsbrugh, PA
Apr 2, 2004
  • Apr 2, 2004
thats problably because he was running lean
T
TheUser
1,859
Springfield, MO
Apr 2, 2004
  • Apr 2, 2004
i'd say check tire pressures. Do you smell gas when you start it? Could be stuck injector. The 4.10's probably aren't helping any.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Apr 2, 2004
#10
  • Apr 2, 2004
  • #10
No need to guess at it just yet - as hissin' suggested originally pull the codes before you go any further. AutoZone/PepBoys will usually do it for free. WalMart sells a scanner for about $20. Search for jrichker here or at corral - in his sig is a site that will tell you how to pull them with a test light and a paper clip - like MacGyver. See what the codes tell you before you needlessly replace parts that you don't have to.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
M
Need help please
  • Mikey62666
  • Oct 12, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 14, 2026
gkomo
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
