Please Help....
  • Thread starter Thread starter stanggirl95
  • Start date Start date May 30, 2008
stanggirl95
  • May 30, 2008
I need some help here guys......Cant a girl just enjoy her convertable.
My car is really sluggish and its driving me crazy.
The car is a 95 GT 5.0
So far I have changed and replaced the cap and rotor, plugs (bosch iridium 4), ford racing 9mm wires, pressure regulator, and have tested my fuel pressure. and its still doing it.
on top of that I have a broken rear sway bar that needs to be replaced.
Any Ideas????
mustangfan1990
505
Lenoir, North Carolina
May 30, 2008
  • May 30, 2008
sorry need a little more info on how the car is running. What do you mean sluggish? Does it do it in every gear? certain rpms? Has it ran good recently? Did you run the car hot (overheating) Have you checked the oil? lots of questions but need more info
stanggirl95
  • May 30, 2008
What started all this was I would drive the car get it warm and I would turn it off and start it again in like 20 mins and it wouldnt start.....When I would drive it, it was fine.
I changed the plugs and it still did it....finally changed the cap and rotor and plugs wires and now its running bad.
The car does it through the entire gear range at low rpm's...its like the car sputters almost like a lean miss.
I changed the fuel pressure regulator and nothing....the fuel pressure whn primed is 40 and at idle is about 32-35
I have always wanted this car, and now I cant even drive it.....
LiquidGT
368
Near STL hell
May 30, 2008
  • May 30, 2008
It might be the TFI module, I dont know how often the remote mounted modules crap out, but I know they still can.
EDIT: Get some regular copper Motorcraft plugs, that will make it run better too.
SPEEDYLIFSAVR
666
FL,89 LX 5.0
May 30, 2008
  • May 30, 2008
I agree with LiquidGT about the plugs . Double check your firing order and make sure its right . If you replaced the cap&rotor double ck TDC and the rotor is at #1 . Is it throwing any codes? sounds like fuel pressure is good , maybe a spark issue or sensor . How does it idle?
stanggirl95
  • May 30, 2008
it idles good.......what is the tdc? Also, what do you mean rotor at #1
HISSIN50
34
129
May 31, 2008
  • May 31, 2008
Any codes?
If not done recently, clean your MAF. The load-based processors are anal about proper MAF function.
If the car won't restart but it cranks, get it to do this and check for spark and injector pulsing. The 94-95's have PIP issues more commonly than TFI issues.
Good luck.
P.S. The broken rear anti-sway bar affects lots of 94-95 folks. Dont feel alone.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 31, 2008
  • May 31, 2008
Some things to have checked when you have a no start condition. Hissin's comments about the PIP can be checked by using section 1 D.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
Revised 08-Mar-2008 to add wire color to starter solenoid & power ground check for computer.
1.) Remove push on connector (small red/blue wire) from starter solenoid and turn ignition switch on. Place car in neutral or Park and set the parking brake. Remove the coil wire from distributor & and hold it 3/8” away from the engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if so equipped
B.) Coil
C.) TFI module
D.) PIP sensor in distributor. The PIP sensor supplies the timing pulse to trigger the TFI and injectors. See paragraph 5A - a noid light will tell if the pip is working by flashing when the engine is cranking.
E.) No ECC or computer power - ECC or computer relay failure
86-93 models only: ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) No ECC or computer power - fuse or fuse link failure
86-93 models only: Fuse links in wiring harness - look for 12 volts at the fuel injector red wires. All the fuse links live in a bundle up near the starter solenoid.
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire. No 12 volts, blown fuse link or faulty ignition switch. Remove the plastic from around the ignition switch and look for 12 volts on the red/green wire with the switch in the Run position. No 12 volts and the ignition switch is faulty. If 12 volts is present in the Run position, then the fuse link is blown.
H.) Bad or missing secondary power ground. It is located between the back of the intake manifold and the driver's side firewall. It supplies ground for the alternator, A/C compressor clutch and other electrical accessories such as the gauges.
I.) Missing or loose computer power ground. The computer has its own dedicated power ground that comes off the ground pigtail on the battery ground wire. Due to it's proximity to the battery, it may become corroded by acid fumes from the battery. It is a black cylinder about 2 1/2" long by 1" diameter with a black/lt green wire. You'll find it up next to the starter solenoid where the wire goes into the wiring harness
J.) Computer
K.) Engine fires briefly, but dies immediately when the key is released to the Run position. Crank the engine & when it fires off, pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Hold the switch in the crank position: if it continues to run there is a problem with either the ignition switch or TFI module. Check for 12 volts at the red/green wire on the coil with the switch in the Run position. Good 12 volts, then replace the TFI. No 12 volts, replace the ignition switch.
See the following links for wiring diagrams...
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
Computer/fuel pump/ignition wiring diagram, 86 model http://www.autozone.com/images/cds/gif/large/0900823d80167158.gif
Computer/fuel pump/ignition wiring diagram, 87 model http://www.autozone.com/images/cds/gif/large/0900823d8016715e.gif
Computer/fuel pump/ignition wiring diagram, 88 model http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
Computer/fuel pump/ignition wiring diagram, 89-90 cars http://www.autozone.com/images/cds/gif/large/0900823d8019595f.gif
Computer/fuel pump/ignition wiring diagram, 91-93 cars
http://www.autozone.com/images/cds/gif/large/0900823d80195960.gif
http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the EEC test connector and jump the connector in the Upper RH corner to ground. The EEC connector is near the wiper motor and LH hood hinge.
If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In a pinch, you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have. If you have any doubts about having sufficient fuel flow/pressure, rent a fuel pressure test gauge from the auto parts store. That will tell you for sure if you have adequate fuel pressure.
C.) Clogged fuel filter
D.) Failed fuel pump
A.) A noid light available from any auto parts store, is one way to test the injector wiring.
The noid light plugs into the fuel injector harness in place of any easily accessible injector. Plug it in and it will flash if the injector is firing.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
D.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
E.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
F.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the 10 pin connectors.
G.) TPS voltage exceeds 3.7 volts with the throttle closed. This will shut off the injectors, since the computer uses this strategy to clear a flooded engine. Use a DVM, a pair of safety pins, and probe the black/white and green wires to measure the TPS voltage.
It should be .5-.99 volts with the key on, engine not running. Note that if the black/white wire (signal ground) has a bad connection, you will get some strange readings. Make a second measurement using the battery post as the ground to eliminate any ground problems. If the readings are different by more than 5%, you may have a high resistance condition in the black/white signal ground circuit.
6.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
stanggirl95
  • Jun 1, 2008
I changed the plugs to autolites #25 and the car is still bucking at 1500-2k rpm's.....any ideas before I run it over with my husbands truck?
Black1987Stang
1,422
Jersey Shore
Jun 1, 2008
#10
  • Jun 1, 2008
  • #10
Mine did that, I cleaned the maf and it got rid of the bucking.
Give it a shot
strtrcr50
Previously from Dirty Jerzey exit 7a
Jun 1, 2008
#11
  • Jun 1, 2008
  • #11
Fill a spray bottle with water and spray the plug wires. See if it gets worse. I've had problems with ford racing wires.
Black1987Stang
1,422
Jersey Shore
Jun 1, 2008
#12
  • Jun 1, 2008
  • #12
Normally if it's a spark arcing problem you feel it most when you put load on the engine, not under light load conditions.
Check engine light on?
I vote for a bad engine coolant temp sensor or air temp sensor, or dirty mass airflow sensor....The computer relies on them to get the right air/fuel ratio.
How is it at wide open throttle?
Pull the codes and clean the maf.
M
MaxTheHooker
36
#13
  • Jun 1, 2008
  • #13
I know it's a n00b mistake, but did you gap your spark plugs? if you did, what did you gap them to? the autolite/motorcrafts should be gapped from anywhere from .52 to .56. i keep mine at a healthy .54
HISSIN50
34
129
Jun 1, 2008
#14
  • Jun 1, 2008
  • #14
0.052-0.056"
strtrcr50
Jun 1, 2008
#15
  • Jun 1, 2008
  • #15
I'm going to stick with my call of bad wires.
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
  • dan50
  • Jul 18, 2026
dan50
Help Identifying Engine Harness Plug
  • FoxbodyRob
  • Feb 7, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Feb 7, 2026
FoxbodyRob
