Please help
LoriC1313
Amory MS
I have a 2000 Stang v6 3.8. I've been trying for 6 months to figure out the problem I'm having with it missing. I've replaced plugs and wires twice, coil pack, intake gasket, fuel filter, and the obvious other things. I'm thinking now that there's an injector that's bad. The #5 cylinder is not hitting leading me to believe that #5 fuel injector is clogged or bad but the shop said they're all working. Help! Could it be the ECU?
  • Sponsors(?)
74stang2togo
Oooh! CT!!!
Mod Dude
Mar 7, 2002
7,550
3,416
224
A misfire is pretty straightforward to diagnose.
1. Switch the spark plugs between the dead cylinder and a cylinder that is firing, and see if the misfire moves, if it does, you need a plug, if not, keep going.
2. Switch the spark plug wires (if applicable) between the dead cylinder and a cylinder that is firing, and see if the misfire moves, if it does, you need wires, if not, keep going.
3. For Coil-On-Plug, Coil-Near-Plug, or 2-plug coil systems, repeat the above for coils. For single coil or coil-pack systems, test the coil using a multimeter and the specifications chart from the manufacturer.
4. Switch the fuel injectors between the dead cylinder and a cylinder that is firing, and see if the misfire moves, if it does, you need an injector, if not, keep going.
5. Use noid lights to confirm you are getting a pulse to the injector on the suspect cylinder from the PCM. If not, use a multimeter to check for continuity through the harness from the PCM connector to the injector connector. If continuity is good, replace the PCM, if not, repair or replace the wiring harness. If all is good, keep going.
6. Perform a compression test. If the compression is low in the suspect cylinder, perform a cylinder leakdown test to see why. If it's high, remove the valvecover and inspect the valvetrain.
Seeing as you've thrown all of the parts for steps 1-3 at it, you're at step 4.
Thread starter Similar threads Forum Replies Date
silverlx50 Engine Help with jrichker's injector testing, more details please Fox 5.0 Mustang Tech 0
R Please Help! Ideas/Tips on how to make my '93 2.3l (NA) Convertible Faster. 2.3L (N/A & Turbo) Tech 6
D Need sct x4 users help please. Digital Self-tuning Forum 0
B 1994 mustang cooling fan wiring? PLEASE HELP!! 1994 - 1995 Specific Tech 0
sams93gt Engine Valvetrain help please!! Fox 5.0 Mustang Tech 10
M Electrical HELP PLEASE! A/C Blowing hot air! 2005 - 2014 Specific V6 Tech 3
markinms Engine surges, cutouts, rough running during acceleration - Help Please! Fox 5.0 Mustang Tech 5
J Please help - 68 Convertible J-Code confirmation/value 1965 - 1973 Classic Mustangs -General/Talk- 1
K Please Help!! Shifting from 1st to 2nd 2015+ (S550) Mustang -General/Talk 1
M 93 fox body 5.0 with no power going to 20 amp circuit breaker at fuse box. HELP PLEASE!! Fox 5.0 Mustang Tech 1
R Help please Digital Self-tuning Forum 0
L Please Help 2013 GT 5.0 The Welcome Wagon 0
M Please help 1989 GT Hatchback.I can not find an L.E.D.smoked 3rd taillight. The Welcome Wagon 4
J Please help '93 mustang The Welcome Wagon 1
9 MegaSquirtPNP 2 problems please help. Digital Self-tuning Forum 12
D 1995 mustang gt 5.0 Need help please! 1994 - 1995 Specific Tech 8
D please help fuel pressure issue 1996 - 2004 SN95 Mustang -General/Talk- 0
B Help please. wiring for alternator upgrade 2010 - 2014 Specific Tech 5
B "Please help" 95 v6 5speed - v8 carb swap The Welcome Wagon 3
A Please help I can't find bushings 2005 - 2014 S-197 Mustang -General/Talk- 4
1 Engine NEED HELP PLEASE!! Fox 5.0 Mustang Tech 4
M Help please new mustang owner 2005 - 2014 S-197 Mustang -General/Talk- 2
G Hey everyone, I'm new here, please help a girl out with some advice! Sell or restore? 1996 - 2004 SN95 Mustang -General/Talk- 58
R Help please. Burns oil, low compression but no broken rings. SN95 4.6L Mustang Tech 1
Lake Martin John VIN help please. 1965 - 1973 Classic Mustangs -General/Talk- 20
D Please help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
L I'm New, Need help. please. SN95 V6 Mustang Tech 1
L Please help 2.3L (N/A & Turbo) Tech 11
S PLEASE HELP 1996 - 2004 SN95 Mustang -General/Talk- 1
J Paint and Body Quarter window weatherstrip help please 1996 - 2004 SN95 Mustang -General/Talk- 1
D Fuel Starts W/ Fluid. Torque App Shows No Fuel Pressure at Rail. Help Please SN95 4.6L Mustang Tech 10
T Please help, a noob needs help with another exhaust question! 2005 - 2014 S-197 Mustang -General/Talk- 5
M Please help need weatherstrip that fastens to interior quarter panel 1965 - 1973 Classic Mustangs -General/Talk- 0
C Just got a 1990 lx notchback. I need help please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
J "Please Help" The Welcome Wagon 2
4 Please help my PCM is flooding my engine Fox 5.0 Mustang Tech 11
Infoxicated5.0 Foxbody lean. Please help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
C Ecu gauges iac and egr problems please help 1996 - 2004 SN95 Mustang -General/Talk- 0
C New Fuel pump, wont start. Please Help! 99 V8 Mustang GT SN95 4.6L Mustang Tech 9
stangbro916 PLEASE HELP!!!!!! 1996 - 2004 SN95 Mustang -General/Talk- 2
B Coolant eruption... car cranks but won’t start... HELP please! SN95 V6 Mustang Tech 5
titanium1990 YJ paint code please help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 34
H Help Please on 1999 Saleen front/rear shock/strut replacement 1996 - 2004 SN95 Mustang -General/Talk- 2
D Please help if possible The Welcome Wagon 8
M Electrical issue please help 1996 - 2004 SN95 Mustang -General/Talk- 3
M Please help with p1450 code 2015+ Specific Tech 0
B 331 t trim 80lb injector tune help please Digital Self-tuning Forum 3
S Electrical Please help 2005 - 2009 Specific Tech 1
L Please help 1996 - 2004 SN95 Mustang -General/Talk- 1
X Alternator\connector question 1996 - 2004 SN95 Mustang -General/Talk- 5
