  • SN95 4.6L Mustang Tech
Please i need help with my nitrous install
  • Thread starter Thread starter 98MACH1R
  • Start date Start date Mar 13, 2007
9
98MACH1R
I wanna put it in so bad, please help.
Jun 6, 2005
131
  • Mar 13, 2007
Hey guys i have a 98 GT and im putting on a zex dry kit, now the directions say for the two rubber hoses, for one to go to the fuel pressure regulator and the other hose to go to the intake. Im so lost and have been searching for a couple of days. I dont know if i should t -off anything or what. If you have pics that would help so much
Thanks stangnet
Saleen4971
664
Setauket, LI
Mar 13, 2007
  • Mar 13, 2007
just T into an existing vacuum line that is coming right off of the intake.
can i ask why your using a dry kit? and why does it need vacuum for a dry kit?
9
98MACH1R
Jun 6, 2005
131
  • Mar 13, 2007
i like using dry so i dont have to worry about puddling issues, i have first hand expierence that back fires will blow an intake. but do you have a pic where you can show me this because i have a vacume on the intake with just a cap over it not being use, could i just put it on that? and what about the fuel pressure vacume line also? thanks for the reply
the98stang
2,408
Clovis, CA
Mar 13, 2007
  • Mar 13, 2007
If you can't install the nitrous kit yourself, you need to have a professional install it, before you ruin your engine.
You better have bigger injectors/fuel rails and high flow fuel pump for that kit, or your going to get lean spikes like crazy.
9
98MACH1R
Jun 6, 2005
131
  • Mar 13, 2007
Thanks man for the heads up but i have installed nitrous before but never a zex unit and never a dry system, i have done many other installs of h/c/i trans swaps, i am very mech inclined, i just need this help with this, btw i have 24`s aftermarket rails and a 255 pump with colder plugs thanks for the help tho.
Stan Weiss
347
Philadelphia, PA
Mar 13, 2007
  • Mar 13, 2007
a fuel pressure vacuum line
9
98MACH1R
Jun 6, 2005
131
  • Mar 13, 2007
yea, i mean like i dont know if i have to tee into it or replace it
Stan Weiss
347
Philadelphia, PA
Mar 13, 2007
  • Mar 13, 2007
yea, I mean like I don't know how one line can have both pressure and vacuum at the same time.
9
98MACH1R
Jun 6, 2005
131
  • Mar 13, 2007
anyone else?
Saleen4971
664
Setauket, LI
Mar 13, 2007
#10
  • Mar 13, 2007
  • #10
if it needs vacuum, then give it manifodl vacuum. if it need fuel pressure (which it should only need for a safety switch) then you have to put a T fitting into teh fuel rails
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 13, 2007
#11
  • Mar 13, 2007
  • #11
that sounds nothing like the zex wet kit i installed a few weeks back.
9
98MACH1R
Jun 6, 2005
131
#12
  • Mar 14, 2007
  • #12
its cause its a dry kit, thanks guys for the reply, im gonna try and get it done today, if you guys have any other things to put in that would be great and pics are always welcome
dastang2
2,020
tx
Dec 10, 2007
#13
  • Dec 10, 2007
  • #13
did you every get it going. the vacuum line is supposed to go from the nitrous regulator to a T fitting with a special vacuum jet inside that i guess only allows vacuum to go into the hose and not pressure from theh nitrous go out to the intake. then there is a hose from the T fitting to the fuel regulator or fuel rail sensor on a 4.6. that is what i take from it. i am not sure though as the 4.6 has a returnless fuel system. this is why i am asking the same question.
twogts4us
4,188
12
79
Dunedin, FL
Dec 15, 2007
#14
  • Dec 15, 2007
  • #14
Did you not get instructions...no pics? That sucks...
The FP switch they are referring to is likely the piece on the driver's side fuel rail.
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
