  • SN95 4.6L Mustang Tech
Please recommned some Spark plugs
  • Thread starter Thread starter 93octane
  • Start date Start date Jul 24, 2004
9
93octane
46
  • Jul 24, 2004
I'm about to change the spark plugs on my 99GT what spark plug should I use. The car is bone stock??? Platinum or Copper and what brand??? It comes with platinum from the factory why should I change to copper?? Thanks
Cobra Jay
889
Motor City
Jul 24, 2004
  • Jul 24, 2004
NGK makes good plugs. I've had VERY GOOD LUCK with them in my snowmobile. I havn't changed mine in my GT yet, but when I do I'll be getting some from them.
www.ngksparkplugs.com
BrightBlue00GT
I am even OLDER than Hawk!
Jun 22, 2000
2,906
Stationed in Korea
Jul 24, 2004
  • Jul 24, 2004
Stick with copper plugs for your setup. Autolite or Champion are very good copper plugs and inexpensive. For your stock ride, why pay more than necessary?
54life
392
Cali currently at Ft. Rucker AL
Jul 24, 2004
  • Jul 24, 2004
i agree copper seem to be the best for the 4.6....stay away from those four prong platinum bull****....many a horror stories from them
03gtstangguy
36
  • Jul 24, 2004
What about Bosch platinum? I understand they work well, especially if you stay with the single prong ones. My T-Bird SC ran those and personally I liked them.
BrightBlue00GT
Jun 22, 2000
2,906
Stationed in Korea
Jul 24, 2004
  • Jul 24, 2004
I used them once before in the stang and they 're crap IMHO. Missed like a SOB. Pulled them, put in some Champion $1.85 copper plugs and it was smooth sailing. This was before the blower. Now I use Desno IT20's.
twogts4us
4,188
12
79
Dunedin, FL
Jul 24, 2004
  • Jul 24, 2004
Copper is more conductive, but has a shorter life. Longer life is the only benefit to platinums. If it's performance that you are concerned with, go for the cheaper copper ones.
Check this very informative thread on ModularDepot:
http://forums.modulardepot.com/showthread.php?s=&threadid=2218
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jul 24, 2004
  • Jul 24, 2004
get Autolite 764s, they are the same as motorcraft. you dont need platnium. the bosch plugs are great for motors designed to use bosch plugs, and the mustang 4.6 was not designed for bosch plugs. the multiprong ones are useless. plus they sell the autolite 764s at walmart for $1 a piece.
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Jul 24, 2004
  • Jul 24, 2004
I already answered this at Fordpower but I'll answer it here for you to. I'm using Motorcraft awsf-c12's gapped at .054 with no problem at all. They are copper and two steps colder than stock.
BAFMustangGT
204
Rochester, NY
Jul 24, 2004
#10
  • Jul 24, 2004
  • #10
I will be use a copper plug (NGK TR-6) for nitrous. NGK = the best...get copper.
twogts4us
4,188
12
79
Dunedin, FL
Jul 24, 2004
#11
  • Jul 24, 2004
  • #11
Why the 2 steps colder plug, Dark Knight? I don't know plugs that well, but from what I've read, colder plugs are best for a motor with a power adder. Why did you decide to use the colder plugs?
-thanks-
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Jul 25, 2004
#12
  • Jul 25, 2004
  • #12
A colder plug is less resistant to electrical charge, hence, they fire better. Yeah, you get better results with boost when using a colder plug, but hey, I figured why not try them. Right now, my SCT tune has my ignition timing setup for 93 octane, I'm running two steps colder plugs, and I have all my mods, yet I'm able to get by with just 87 octane. No pinging, no rattling, no funny idle. Everything rides like a dream.
twogts4us
4,188
12
79
Dunedin, FL
Jul 25, 2004
#13
  • Jul 25, 2004
  • #13
Wow, that would be great to be able to use 87 with the SCT tune setup for 93 especially with today's gas prices (I'm in the same boat with my SCT Tune, but have never tried anything less than 92). No knocks or pings here either at this point (with the OEM MAF back in place!), and I'm due for a plug change, so maybe I'll go with the colder plugs...at least one step colder.
Thanks for the info!
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Jul 25, 2004
#14
  • Jul 25, 2004
  • #14
I think the Amsoil synthetic fuel additive might have something to do with why I do so good in the fuel department. Can't say for sure though.
4.6_02_Black_GT
622
Charlotte NC
Jul 25, 2004
#15
  • Jul 25, 2004
  • #15
I run the standard (single wire) stock Bosch platinum replacement plugs.
wms004
2,864
Los Angeles
Jul 25, 2004
#16
  • Jul 25, 2004
  • #16
Autolites with a .45 gap. 2 bucks each and all you need.. Just be sure you change them every 30k. Paying more for spark plugs is unneccesary and yields no performance gain.
mcmmotorsports
689
Danbury, CT
Jul 25, 2004
#17
  • Jul 25, 2004
  • #17
Denso or NGK copperheads are the BEST for ANY car and ANY application.
68 & 00 GT
2,407
HOUSTON TEXAS
Jul 25, 2004
#18
  • Jul 25, 2004
  • #18
NGK TR 55's, or are they 45's ? One or the other. $1.12 each, Worked great for me n/a, and was recommended by my tuner. I switched to NGK TR 6's when my blower went in.
FYI - do not overtighten your plugs when reinstaling the new ones. Our heads have soft, shallow threads for the spark plugs, they are notorious for stripping the threads. Only turn 1/8 of a turn w/ a ratchet past finger tight, and use spark plug antiseize.
I can tell you which plugs for sure when I get home.
Dark Knight GT
May 26, 2003
3,653
Ozark, Missouri
Jul 25, 2004
#19
  • Jul 25, 2004
  • #19
The NGK TR-55's are stock heat range and if you got them for 1.12 each, they were undoubtantley coppers. If they were Iridiums, they would be about 6-8 times more expensive.
wesl56
83
Tallahassee, FL
Jul 25, 2004
#20
  • Jul 25, 2004
  • #20
V-POWER!!!!! ~~!!NGK 4eva!!~~
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
96 GT 4.6 w/ dirty spark plug well
  • Mustang Momma
  • Apr 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 9, 2026
LILCBRA
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
