  • SN95 4.6L Mustang Tech
Plug change a success!
  • Thread starter Thread starter sbelyo
  • Start date Start date Jun 12, 2005
sbelyo
192
  • Jun 12, 2005
Well I decided to change the plugs in my 01 GT. I haven't even bothered to look for them before so this was my first change on a 4.6L.
Tools Used:
3/8" Ratchet
3/8" Torque Wrench
3/8" 8 in. Ext
3/8" Drive 5/8" spark plug socket
1/4" Ratchet
1/4" 4 in. Ext
1/4" U-Joint
1/4" Drive 7mm socket
Can of complessed air
Permatex tune up kit (Anti seize and grease)
Flat Blade screw driver
So everything I read on this subject is true.
1. Definitely switch to the autolite 764 plug. (the car just feels/runs better)
2. You do need a can of compressed air. (there's a buch of dirts that falls into the well)
3. No, the fuel rails DONT have to come off. (the coil/boot is flexable enough to move out from under the rail)
4. Yes, take the intake tube off of the throttle body. (makes the passenger side much easier)
5. And remember to re-connect all of the coils and connectors. (not that I made that mistake) Or did I?
I gapped them all 0.054 and used anti seize on the threads and electro grease on the tip.
I threaded them in by hand, backing them out once or twice until no friction occurred.
I torqued them to 13 foot lbs. or 156 in lbs.
The car runs better now with 70K miles on it then it did new!
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jun 12, 2005
  • Jun 12, 2005
good job.. you even tourqed them right. i just finished a cylinder head on a 5.4 truck on friday that the guy changed plugs and did'nt tourqe them right. he blew one of the plugs out of the head lucky for him he had a extended warrenty and i never told the writer why it blew out of the head.
Black2001GT
1,267
Saints fan Stuck in FalCANTs country
Jun 12, 2005
  • Jun 12, 2005
Subscribing, I got allot of time on my hands next week.
Ghostface
226
Jun 13, 2005
  • Jun 13, 2005
same here
HoustonGT
Gilded Gelding
Apr 6, 2003
1,418
Houston
Jun 13, 2005
  • Jun 13, 2005
Yup, i had the same Autolite 764 plugs in my GT. The car just felt better at idle and seemed a bit smoother.
9646gt
595
Holloman AFB,NM
Jun 13, 2005
  • Jun 13, 2005
I too like the autolite plugs..feels alot better than the NGK platinum plugs I have ran before..
SilverGTV8
295
West Brookfield, MA
Jun 13, 2005
  • Jun 13, 2005
I did the Denso's this weekend. Took an hour from start to finish. Everything went very well. And as stated by "sbelyo" it was cake.
Car runs smoother. The plugs that came out looked like the car is running good, maybe a tad lean but come next saturday that will be fixed, running on the dyno.
twogts4us
4,188
12
79
Dunedin, FL
Jun 13, 2005
  • Jun 13, 2005
It is really easy and straightforward...I followed the Bullitt write up. I ended up taking about 1.5 hours because I chased each hole with the old plug SEVERAL times (each time with fresh anti-seize) until, as sbelyo did, it ran down without resistance. Even though I throughly blew out each plug hole, there still seemed to be alot of sand, grit and 'whatsnot' on the threads. Fortunately, I invested in an air compressor (15gal Craftsman), which was probably the best 'tool' I've purchased in a long time. Anyway, I just thought it made a lot of sense to get those threads as clean as possible...remember, aluminum heads!!!
My lower back was a bit sore after leaning over the engine for so long (I'm just getting old!), but other than that, this is fairly easy. Did it seem to make at difference (at 30K miles)? Nope. Mine still doesn't idle as well as the wife's 01 with 15K miles more. (Maybe it's those Denso's in hers? - doubtful) Weird, cause it is smooth as silk at idle with the A/C on...but it almost seems to miss with it off. Just a bit rougher than it should be.
Anyway, for those who don't know the link (an alltogether great site) - http://www.bullittarchive.com/html/modules/articles/article.php?id=83
R
rjstaaf
1,310
Somewhere
Jun 13, 2005
  • Jun 13, 2005
One thing that might help keep some of the crap from getting into the plug holes is to put some dialectric grease on the boot where it seals at the top of the plug holes. The grease should trap and hold a good bit of the debris and keep it from going into the hole. This has worked for me. I still blow out the holes with my compressor before removing the plugs but, this has noticably kept the debris to a minimum.
twogts4us
4,188
12
79
Dunedin, FL
Jun 13, 2005
#10
  • Jun 13, 2005
  • #10
Excellent idea - thanks!
sbelyo
192
#11
  • Jun 13, 2005
  • #11
It looked a little daunting at first but I had the driver's side done in 30 min. The passenger side took me and hour because I was bs'ing with my neighbor.
But it's well worth it. The car just friggin feels better. The idle is baby smooth at 70K miles.
Actually today I stopped into a car detailing place and had them clean the engine bay. Then it started to miss and tripped the CEL. I was like NO, Why did I do that.......
So I got it home and blew all the water that collected by the injectors and left it in the sun with the hood up and Neg. Batt terminal disonnected for an hour.
That solved the problem and everything is back to normal. A ford tech was telling me that it sounded like a coil got wet, and if it mis-fires so many times in a few cyles it will trip the CEL. As stated above by someone, he told me to grease the top of the boot where it meets the head next time.
Holiday Gift Tool Ideas
  • gkomo
  • Dec 17, 2025
  • Off-Topic Hangout
Off-Topic Hangout Dec 18, 2025
General karthief
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
J
Spuddeeing 06 4.0!
  • jester242
  • Dec 22, 2025
2005 - 2014 S-197 Mustang -General/Talk- Dec 22, 2025
jester242
J
  • dan50
  • Jul 18, 2026
dan50
