  • SN95 4.6L Mustang Tech
Plug keeps walking...
  • Thread starter Thread starter ponygt
  • Start date Start date May 3, 2011
ponygt
11
Victorville, Ca
May 3, 2011
  • May 3, 2011
i have a 2000 gt, about two weeks ago i heard a tick coming from the motor (sounded like it was coming from the bottom end).. i already knew it was from the plug(s) and immediately checked them, a couple were loose. re-tightened, and tick went away. just a few days later the tick came back, so i pulled the little ****er out and doing so, it pulled the damn threads out with it.. uhg. had it fixed on wednesday (timesert) and just today another one was loose but i pulled it out and the threads were okay.. what should i do?
D
Deleted member 38176
May 3, 2011
  • May 3, 2011
I just had one of mine walk on me last week. The only thing I could recommend is to 1.) make sure the plug well, head threads, and plug threads are completely clean 2.) tighten the plugs when the heads are as hot as possible (as hot as you can safely manage) 3.) torque them down to the proper specs
If they continue to back out after that then there could be a problem with the threads in your heads.
midnightdriver
443
Northern California
May 3, 2011
  • May 3, 2011
I though you were only suppose to change the plugs when the engine was cold, ice cold?
If I were you I would buy some new plugs and add some anti-seize to them and see if that helps. How are you tighting them? Suppose to be between 11 and 14ft-lbs IIRC.
Could you use high temp lock tight? I honestly don't know, might take the whole head off when you change the plugs next time. But plugs backing out is a warning sign.
Rick 91GT
Mustang Master
95
99
PA
May 3, 2011
  • May 3, 2011
Pulling plugs out while warm is ok, but you should install cold to prevent any accidental cross threading.
Antiseize will help future removal, but not help retain them. Is it possible you didnt have them tight enough?
Timesert is a good repair, that damn repair kit is expensive I picked it up a few years ago.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
May 3, 2011
  • May 3, 2011
NOO! thats the worst thing you can do, we only have very few weak aluminum threads and they will pull out extremely easy when the engines warm!
Maxpowers
859
Pittsburgh, Pa
May 3, 2011
  • May 3, 2011
Always perform plug changes on a cold motor. Let it sit overnight.
What did you torque them to?
98COBRA281
1,348
30
59
May 3, 2011
  • May 3, 2011
13ftlbs, or 156 INlbs, its more accurate at lower TQ specs
Maxpowers
859
Pittsburgh, Pa
May 3, 2011
  • May 3, 2011
That was a question for the op.
D
May 3, 2011
  • May 3, 2011
Oops ya I had it backwards. COLD COLD COLD!
ponygt
11
Victorville, Ca
May 5, 2011
#10
  • May 5, 2011
  • #10
15lbs
and thanks guys for your help.
its just so annoying.
The problem came when i changed the plugs. Im the second owner and the first had it for over 9 years. i dont think the A hole ever changed the plugs lol the car is incredibly clean in and out so i assumed he took excellent care of it.. anyways.. I changed the plugs a few months ago and they were tighter than the lugnuts on a foxbody running radials. im assuming that f'd it right there.. they were damn near welded in there. After that i've had nothing but problems with them, #3 had a timesert last wednesday..
ponygt
11
Victorville, Ca
May 5, 2011
#11
  • May 5, 2011
  • #11
btw i did them cold, i know better than that lol
duuscru2
12
PA. 80 mi. east of pittsburg
Jul 20, 2011
#12
  • Jul 20, 2011
  • #12
up here in the mountains we have that problem alot. how hard has this engine been run under load? I see at least 4 or 5 4.6s a year that this happens to . ... heilcoil
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
Jul 20, 2011
#13
  • Jul 20, 2011
  • #13
Blue Lock-Tite, preferably the paste.
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
J
'04 3.8L V6 mineral deposits and oil on #3 cylinder. Does it need a rebuild or something simpler?
  • joeybuddy96
  • Mar 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 29, 2026
gkomo
