  • SN95 4.6L Mustang Tech
Plug question
  • Thread starter Thread starter donsbad68
  • Start date Start date Aug 30, 2004
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 30, 2004
  • Aug 30, 2004
What plugs are stock in my 02 GT and what would be the best to put in? I'm going to stay N/a so a good hot plug please.
Dust-n
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Aug 30, 2004
  • Aug 30, 2004
I'm not too sure what the stock number is for the plugs but they are going to be a Platinum Motorcraft plug, that much I know for sure. As for whats a good plug to use for a n/a application, most use copper spark plugs and just change them out every year. I run Motorcraft awsf-c12's. They are copper and are two steps colder than stock. If you want stock heat range, I'm not sure what the Motorcraft number is but Autolite makes a 764 series copper plug which will work. Its copper and stock heat range as well. You could also use Iridium plugs which will are more conductive than platinum but will last far longer than copper. However, they are really expensive.
donsbad68
Immensely Educated
Jan 4, 2003
838
Oklahoma
Aug 31, 2004
  • Aug 31, 2004
hmm.....so anybody know the denso plug numbers?
KaPPaBaLL
1,326
BAYAREA
Aug 31, 2004
  • Aug 31, 2004
you don't need iridiums though some say they get better gas mileage and it has paid for themselves. I say just go with $1 autolite 764's and be done with. DO NOT CROSS THREAD. Use anti-seize (just a dab or it). and torque it to specs.. 9-14lbs
rpayne20
77
MI
Aug 31, 2004
  • Aug 31, 2004
what difference does the heat range make??? is running a cloder plug better???
KaPPaBaLL
1,326
BAYAREA
Aug 31, 2004
  • Aug 31, 2004
no not necessarily. Running a colder plugs are only necessary only when running some sort of poweradder such as SC, Turbo, or Nitrous Oxide. It's a lot less prone to detonation and overheating of stock heat range plugs. If you are staying n/a it's urged that you stay with your stock heat range for maximum results. i use autolite 764's and nothing but impressed with them. With little bit better gas mileage. I gained 1-2mpg but for $1/per plug you can't beat that.
Turbo92PGT
746
Auburn Washington
Aug 31, 2004
  • Aug 31, 2004
Either go autolite 764 or go with NGK TR55's. Ive had really good luck with the NGK's.
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
  • Mindseye007
  • Aug 16, 2026
Mindseye007
For Sale Fox BRAND NEW Motorcraft spark plugs, wires and hood prop rod clips
  • Ricomondo
  • Sep 6, 2026
  • Engine and Power Adder
Engine and Power Adder Sep 6, 2026
Ricomondo
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
