Plugs and wires
it would be best to keep them somewhat similar (dont cross them up or something). but taking a different path is fine. just be careful of crossfires, etc from wires being crossed.
good luck.
I was once told when I change wires to make sure the wire where over lap now. Cross each wire the same way. I was also told just run them and make sure to do just one wire at a time.
Thanks for the help!!
sounds good to me. you should be able to have them overlap whereever you want. note that generally overlapping of wires (or even touching) is not desired.
doin the wires one at a time is a nice way to keep from getting a wire crossed or using the wrong firing order, etc.
good luck.
