I took a look at my plugs and they are white, some are and some arnt? I check codes and running codes and got nothing? i mean i can take a cloth and wipe it and it comes right off but... what can i do? i dont want my car running lean?
What is your timing set at? If it's too far advanced you're going to get that. Do you have an adjustable FPR? If so you might want to bump your fuel pressure a bit. If its' only certain cylinders you might want to clean your injectors. Some of them might be starving some of your cylinders.
Dude, your running lean in either those cylinders or your are just plain running lean across the board. Check the injectors and clean them all out if that doesn't work go to the dyno and get it measured.
I wouldn't really step on it still you get it fixed, running lean isn't a good thing..
yea, i checked my timing and it is set right at 10* today! How do u clean the injectors out? Just fuel injector cleaner? I just ran sea foam threw like last week?
