plugs to use for NOSzle
Motorcraft AWSFA22C gapped at .032 If the dealership doesn't have in stock they can order. They are cheap, reliable, and commonly used in blown or juiced applications for 99+ cars.
This is one heat range colder than stock and should serve your needs just fine.
autolite- 103's, denso- IT20 but I wouldn't reccomend the Denso plugs.
the other parts listed are all 1 step colder. Wall Mart has the autolites sometimes and are about $1.00 each. Advance also carries autolite. Ford usually has the awsf22c( make sure not to get awsf22p, those are platinum) . :D
I found this in a thread somewhere, maybe this will help.
MOTORCRAFT
PART# / HEAT RANGE
AWSF-32C / stock heat range - cooper plug
AWSF-22C / 1 Heat range colder - cooper plug
AWSF-12C / 2 Heat range cooler - cooper plug
AGSF-32C/ Recommended for FRPP heads(not sure on heat range)
NGK
PART# / HEAT RANGE
TR-55/ 3951/ Stock Heat Range
TR-6/ 4177/ 1 Step Colder
PART# / HEAT RANGE w/ .750 THREAD DEPTH
R5671A-7/ 4091/ stock heat range
BR7EF/3346 / 1 steps colder
R5671A-8/ 4554/ 1.5 steps cooler
R5671A-9/ 5238/ 2 Steps Colder
R5671A-10/ 5820/ 3 Steps Colder
FOR 99+ CARS w/ .708 thread depth
PART# / HEAT RANGE
BP7EFS (PN - 3526) two steps
R5724-8 (PN - 7317) two and a half steps
R5724-9 (PN - 7891) three steps
R5724-10 (PN - 7993) four steps
AUTOLITE
PART# / HEAT RANGE
764s / Stock
103s / 1 heat range cooler
AR94 / 2 heat range cooler
AR93 / 3 heat range cooler
AR92 / 4 heat range cooler
CHAMPION
PART# / HEAT RANGE
YS-59C / -3 or -4 below stock heat range
DENSO
PART# / HEAT RANGE
IT16 / stock heat
IT20 / -1 heat range
IT22 / -2 heat range
IT24 / -3 heat range
bg00gt said:
hey folks im abuot to get hooked up on a NOSzle system and wondering who her has one and what kind of plugs to use?
I am using the NOSzle system with the 125hp shot on my 2001 GT. I decided to go with the Autolight racing AR94, which is two ranges colder. So far I have been extremely pleased with there performance. The AR94 is a copper core plug with the electrode cut back. I have my gapped at .040 and everything seems to be running great.
