Ok, I just went out and hooked up my PMS for the first time. I went through the tables and zeroed everything, Part Throttle, WOT, made sure stand-along and boost was turned off, all that stuff. I think i got everything.
Anyhow, i think everything is zeroed, so i saved it to all three program spots then loaded one and fired it up. She's all warmed up so I took it for a drive and was watching the screen (safely) Anyhow, I stomp it in 2nd and around 5k it starts sputtering like a rev limiter. So i went into the menu's and found the 1st limiter set at 5k. Is that whats causing it? Im not sure how that is activated?
Second question is I also watched my Injector duty cycle and it peaked at around 94% So looks like its time for new injectors? I figured it was but it's nice to see some proof.
I also watched timing and it peaked at 31, no crazy numbers there
And lastely, since i don't have a wideband *yet* would it be ok w/ new injectors just to add fuel to be safe for awhile?
Thanks, and sorry for the novel
Thanks, Will
Thanks, Will
??? the PMS cannot pick up on something that a factory ign. has no problems with until a poweradder or high comp. is tossed on/into the eq?
