PMS or Chip HELP!!!!!!!!!!!!!!!!!
  • Thread starter Thread starter 89CobraGT
  • Start date Start date Feb 9, 2006
89CobraGT
113
Winnipeg manitoba
Feb 9, 2006
  • Feb 9, 2006
Well im going with the pwerdyne s/charger 9psi this year but I wasnt aware that I would need a pms or a custom chip for my car to run properly until recently can someone tell me what a pms is??? and where I can get one?? or where I can get a custom chip made???? Thanks alot for everyones replies!!!
Tonys96Cobra
professional deer "mounter"
Oct 28, 2005
29
Syracuse
Feb 9, 2006
  • Feb 9, 2006
Dont get the PMS!!! They go all crazy like once a month!! Really sux!!!
JK, I couldnt resist
89CobraGT
113
Winnipeg manitoba
Feb 9, 2006
  • Feb 9, 2006
Lmao thanks man
89CobraGT
113
Winnipeg manitoba
Feb 10, 2006
  • Feb 10, 2006
BUMP!!!
L
luckythirteen13
648
Anaheim, CA
Feb 10, 2006
  • Feb 10, 2006
http://andersonfordmotorsport.com/ has the pms
custom chips are burnt at a dyno shop
what you have to keep in mine is that with the pms you will need a map sensor and a wide band o2 set up (one that records) the pms with all the other stuff you need is going to set you back 1300-1400 with map and wide band. and you will be tuning the car yourself. setting fuel pulse width and timing advace curves. if you dont know what the hell your doing your engine could be destroyed.
dyno tuning is usually 400 for the chip and 200 an hour for labor of tuning
other things you may have over looked is bigger fuel injectors(42# is good for your boost level), bigger maf calibrated to the larger injectors, bigger fuel pump, msd ignition box (if you dont have one). a sc will only supply more air, you have do compensate with a lot more fuel
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
