  • 1994 - 1995 Specific Tech
PMS Users, need your help!!
  • Thread starter Thread starter FastGT94
  • Start date Start date Sep 1, 2004
FastGT94
300
NW Burbs, IL
Sep 1, 2004
  • Sep 1, 2004
Greetings!
I recently installed the PMS on my car and I’m wondering about a few things.
On the display there is a reading for the o2 sensors and if I’m in neutral and standing still, the numbers will read rich from 1,000 to 2,000 rpm. Anything after that just goes instantly lean. However, this number jumps between lean and rich a lot when I’m giving it slight throttle below 2,000 rpm while cruising. Also, anytime over 2000 rpm while cruising, the voltage just drops to 0.2L on both banks and stays there. This is with no settings in the PMS and just monitoring the stock EEC settings.
Also, when I tried to put some settings in for idle control or WOT, I added 16* timing to the initial 10* and was coming out with 40-45+* when just cruising around! I had the timing at idle set at 17* but with the idle control off. 40+* timing just seems way too high.
When I turned idle control on, with it set at 850 rpm the car idles at around 1400 rpm.
I guess I’m just looking for some guidance on this.
When I did add settings, this is what it looked like (based on rel3rd's stuff):
N/A 94 GT w/Heads, Cam & Intake (NEW PMS unit)
Year model: 1994 Mustang GT
Engine cubic inch: 302
Power Adder/NA: N/A
Intake: GT-40 Upper/Ported Lower
Throttle Body: BBK 65mm
Mass Air Meter: Pro-M 75mm "bullet"
Intake Piping: MAC CAI
Cylinder Head & rockers: AFR 165 58cc 1.6 Scorpion Rockers
Camshaft profile: FTI ~ .550” / .540” 224* / 228* 110 LSA
Injector Size: FRPP 24lb/hr.
Header size/type: BBK 1 5/8” Long-tubes
Fuel Pump(s): Walbro 255lph intank
Rails: stock
Supply/Return Line size: stock
Fuel type: 93 octane unleaded pump gas
IDLE Control On/Off: ON
fuel: -4%
rpm: 900
timing: 17*
start-up fuel: -9%
idle air adjuster: 53%
ALL PART THROTTLE Parameters (Fuel first/Timing second)
________LL____2____3____4___ML__5______6_____7_______HL
2000rpm: 0/0___0/0___0/0__0/0__0/0_+20/-0, +20/-0, +20/-00, +20/-00
2500rpm: 0/0___0/0___0/0__0/0__0/0_+20/-0, +20/-0, +20/-00, +20/-00
3000rpm: 0/0___0/0___0/0__0/0__0/0_+18/-0, +18/-0, +18/-00, +18/-00
3500rpm: 0/0___0/0___0/0__0/0__0/0_+16/-0, +16/-0, +16/-00, +16/-00
4000rpm: 0/0___0/0___0/0__0/0__0/0_+16/-0, +16/-0, +16/-00, +16/-00
4500rpm: 0/0___0/0___0/0__0/0__0/0_+14/-0, +14/-0, +14/-00, +14/-00
5000rpm: 0/0___0/0___0/0__0/0__0/0_+10/-0..+10/-0..+10/-00..+10/-00
5500rpm: 0/0___0/0___0/0__0/0__0/0_+10/-0..+10/-0..+10/-00..+10/-00
6000rpm: 0/0___0/0___0/0__0/0__0/0_+8/-0....+8/-0....+8/-00....+8/-00
6500rpm: 0/0___0/0___0/0__0/0__0/0_+6/-0....+6/-0....+6/-00....+6/-00
WOT (Fuel first & Timing second)
2000rpm: -10/+16
2500rpm: -12/+16
3000rpm: -12/+16
3500rpm: -12/+16
4000rpm: -12/+16
4500rpm: -12/+14
5000rpm: -12/+13
5500rpm: -14/+12
6000rpm: -14/+10
6500rpm: -14/+8
fahrenheit
DEGREES......AIR TEMP.....WATER TEMP (fuel first/timing second)
-10.....................+8/0_________0/0
0....................….+6/0_________0/0
40......................+2/0_________0/0
70.......................0/0__________0/0
100......................0/0__________0/0
130.....................0/0__________0/0
160......................0/0__________0/0
210.....................0/0__________0/0
250......................0/0__________0/0
ACCEL menu
Response...20%
Recovery...20%
All fuel & timing settings at ZERO
STANDALONE On/Off: ON
Fuel Trigger TPS: 50%
Fuel Trigger RPM: 2000
Timing Trigger TPS: 50%
Timing Trigger RPM: 2000
Rev Limiter: 6500
Global Fuel: 0
Notes: Bad jerking below 1500 (worse than with no settings), lean after 2000 (.02-.06L)
Thanks!
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Sep 1, 2004
  • Sep 1, 2004
When the O2 sensors are jumping back and forth, that means you are in closed loop, and that's a good thing. Anytime they go one way or the other and stay, it means that the EEC is in open loop -- in that situation you cannot really derive any meaning from the O2 sensors, as they are narrow band and quite useless for mixture not stoich. With your head/cam/intake combo, the calculated load is probably high, which makes the EEC go into open loop more often and easily than when stock. There are ways to fix this, but I don't know how on a PMS.
Having over 40* of timing when the engine is unloaded (or coasting in gear) is normal.
Can't help with the idle problem, I'm a TwEECer user not a PMS user . Maybe someone else can chime in with some ideas as to why it's not taking correctly.
Dave
T
TMC
1,426
Chicago
Sep 1, 2004
  • Sep 1, 2004
The idle settings on the PMS are not truely accurate. Setting the idle RPM is more of a reference number than an actual number. You really need to set the idle to where you would like, say the 850 you have it at. Then, play with the IAC control % to make the major changes to how high it idles. The more you open it the higher it will idle. So, turn it down some and see what happens.
FastGT94
300
NW Burbs, IL
Sep 1, 2004
  • Sep 1, 2004
So don't worry about the actual desired rpm number in the PMS and just play with the IAC %?
T
TMC
1,426
Chicago
Sep 1, 2004
  • Sep 1, 2004
pretty much...set the desired number where you want but be aware that you may need to play with that as well. The IAC% will do most of the changes.
  • dan50
  • Jul 18, 2026
dan50
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
For Sale 2000 GT Conv 4.6 block, heads lots of misc engine parts all removed,degreased, cleaned and inspected.
  • Tods Hot Rods
  • Sep 17, 2024
  • Engine and Power Adder Parts
Engine and Power Adder Parts Sep 19, 2024
Tods Hot Rods
