  • SN95 4.6L Mustang Tech
Poly Rack Bushings
  • Thread starter Thread starter MrGame
  • Start date Start date Aug 26, 2007
MrGame
52
  • Aug 26, 2007
How much of a difference do urethane rack bushings make in correcting that crappy steering play? I know the shaft is the biggest part of the problem, but I haven't put my bushings in my car yet and i'm anxious to know how much of a difference they make
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Aug 27, 2007
  • Aug 27, 2007
Well, there is not much of a difference. The stock rubber ones are prone to degrading. When I switched my GT to MM urethane the rubber stockers I removed were shot. It tightens things up a little but not much. On the Cobra I went with the aluminum rack bushings, they suck because there is some noise (steering gear clunks against k-member) especially when backing out of driveways. I have tried urethane, rubber, and aluminum. IMHO the urethane is the best.
Chnaging the bushings is more about preventitive maintenance then performance but you will feel a small difference.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
Sloppy steering wheel
  • cnorman31
  • Nov 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 2, 2025
Monkeybutt2000
M
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
