  • 1994 - 1995 Specific Tech
Poor gas mileage question
  • Thread starter Thread starter Project 77
  • Start date Start date Jul 25, 2004
Project 77
370
Bernville PA
Jul 25, 2004
  • Jul 25, 2004
OK I am getting terrible mileage out of my car...like 125-150 miles on a tank of gas whereas I used to be able to squeeze almost 245 out of a tank. My car has a motorsport X cam, and initially it had 24 pound injectors, well i went back to matching 19 pound injectors and stock mass air meter, since then mileage is bad.Still has stock 3.27 gears, O/R H pipe and SLP exhaust.
I should Add that when it's idlling you get a real strong gas odor from the exhaust
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jul 25, 2004
  • Jul 25, 2004
maybe you have some bad O2 sensors or you forgot to plug something in
chrismillion
20+ Year Stangneter
Mar 4, 2004
259
  • Jul 25, 2004
sounds like the o2 sensors, have your car put on a scanner to see if any codes have been picked up. that will explain your bad gas mileage and the smell, cause your car is probably running lean. one other thing is the charcoal canister can make your car smell of gas fumes, but i don't think it affects your gas mileage.
Project 77
370
Bernville PA
Jul 26, 2004
  • Jul 26, 2004
where are the O2 sensos on a car with an O/R H pipe?? I thought they screwed into the bung on the old stock H pipe, my H pipe didn;t have a place for them and I think whoever did my exhaust just taped them to the underside of the car maybe????
HISSIN50
34
129
Jul 26, 2004
  • Jul 26, 2004
updated list of things to check. pull codes and then find your O2 sensors. no one would be so inept as to tape the O2's up. naw. ok, maybe.
good luck.
mystang94gt
951
Bay Area, CA
Jul 26, 2004
  • Jul 26, 2004
The O2 sensors are right where the h-pipe meets the headers....
Another thing in case it isnt the o2 sensors, I was having a similar problem with my car and came to find out one of my spark plugs wasnt gapped correctly (it was almost pinched closed) resulting in one of my cylinders misfiring. That made the gas milage horrible and the smell of gas was really strong since there was a lot of unburned fuel going through the exhaust.
For Sale 2000 GT Conv 4.6 block, heads lots of misc engine parts all removed,degreased, cleaned and inspected.
  • Tods Hot Rods
  • Sep 17, 2024
  • Engine and Power Adder Parts
Engine and Power Adder Parts Sep 19, 2024
Tods Hot Rods
For Sale 94 Cobra 408w AOD Project For Sale
  • Labora
  • Oct 11, 2024
SN95 Mustangs For Sale (1994-04) Aug 17, 2026
Labora
my '00 3.8L has a couple issues, need insight.
  • 305newedge
  • Jul 5, 2021
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 27, 2021
Toofastt
H
Terrible Gas Mileage on 2013 V6 Mustang
  • headhunter07
  • Jun 2, 2020
  • 2010 - 2014 Specific Tech
9K
2010 - 2014 Specific Tech Jun 13, 2020
mikestang63
E
04 Mustang GT Gas Mileage
  • Envro
  • Aug 11, 2019
1996 - 2004 SN95 Mustang -General/Talk- Aug 12, 2019
Decipha
