ok guys heres the story, i had msd ignition installed, and the car started giving me problems until it wont even start, i took it to a shop and they took off the msd ignition and changed the msd coil packs to stock coil packs. i pick up the car and the car is running like ****, at 1500rpm it shaked like a... unbelivable, when i check the sparks in the coilpacks 2 cylinders are not even firing, so i change spark plugs and change back to the msd coil packs the all 8 cylinders fire now but the car still runs very bad, sound nasty and i scense a strong fuel smell every time i drive it, today i popped up the hood and took a look, i check the connectors that go to the injectors and the car reacts on 6 of them (meaning the shaking increases, but 2 of them I can connect and disconnect and the cars idle wont change at all. Is this an electricity problem? or an injector problem, because have in mind that its 2 of them failing.
I do have a diablo chip and Ill try disconnecting the battery and the chip tonite, please keep me posted if you think about anything else.
