  • SN95 4.6L Mustang Tech
Pop
  • Thread starter Thread starter 96greenGT
  • Start date Start date Jun 17, 2005
9
96greenGT
23
FC,AR
Jun 17, 2005
  • Jun 17, 2005
in november my car started making this popping noise in the front end when I stopped unless I stopped really carefully and slow......it sounds like a creaking noise that turns to a pop and when I get going again it pops back into place.....I have replaced the struts, caster camber plates, lower control arms, brake pads, and the ball joints and I am out of ideas.....I can't find any obvious worn spots or anything so any ideas yall have please throw them out....thanks, Ira
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 28, 2005
  • Jul 28, 2005
Mine is doing the same thing. I haven't gotten under it to see what it is. If anyone has had this problem let us know.
Red03Mustang
373
  • Jul 28, 2005
My car pops when I brake hard. Other than that, I have no pop. But, it could be related.
triggz
1,218
Gadsden, AL
Jul 28, 2005
  • Jul 28, 2005
Tighten down the swaybar endlinks and/or upgrade to poly bushings. Common problem for them to 'pop' around on the threads if they become loose or the bushings wear out.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Jul 28, 2005
  • Jul 28, 2005
I'm almost positive that you guys have a bad hub bearing. I had the same sound in my last car. Have it checked out and IF that is the problem, you need to have it fixed ASAP.
02GT/65coupe
66
alabama
Sep 14, 2005
  • Sep 14, 2005
if you have a lowered car you need to get shorter sway bar endlinks to fix the geometry of the sway bar. do a search for it on the net and you will find stuff about it and see what the best size is for you.
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Rear sway bar popped off
  • Creomod
  • Jan 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 16, 2025
limp
