  • SN95 4.6L Mustang Tech
Popping when shifting
  • Thread starter Thread starter Sick96Stang
  • Start date Start date Nov 29, 2004
Sick96Stang
621
Gilbert, Arizona
Nov 29, 2004
  • Nov 29, 2004
When I am pushing the car hard and I shift quickly sometimes it will make a loud popping noise is this backfire in the intake? If it is backfire in the intake how do I fix it? If not what is causing this sound and how do I fix it?
merc123
420
North GA
Nov 29, 2004
  • Nov 29, 2004
Could be detonation. What fuel are you using?
Sick96Stang
621
Gilbert, Arizona
Nov 29, 2004
  • Nov 29, 2004
87 Octane, it could be detonation but I dont know what would be causing it I'm not running any serious mods that should require me to up the octane?
merc123
420
North GA
Nov 29, 2004
  • Nov 29, 2004
Are you pulling any codes? It could be a misfire.
Sick96Stang
621
Gilbert, Arizona
Nov 29, 2004
  • Nov 29, 2004
yea my check engine light is on because of my O/R H-pipe, I have the MIL's but it still gives me the check engine light.
S10V8
20
Canada
Nov 29, 2004
  • Nov 29, 2004
Could be raw fuel exploding in the exhaust, I know a guy with a supercharged 306 that when he lets off the gas it pops .
merc123
420
North GA
Nov 29, 2004
  • Nov 29, 2004
Did it always have a CEL even after the MILS?
jrc_03_gt
786
  • Nov 29, 2004
I have a friend that has a 94 cobra and we put a bbk fenderwell mounted cold air intake and his did the same thing. It only did it after we installed the cold air intake.
merc123
420
North GA
Nov 29, 2004
  • Nov 29, 2004
So you're saying that it could be his desenger?
jrc_03_gt
786
#10
  • Nov 29, 2004
  • #10
I can just tell you what happened to me and my friend. Did you have the problem before the densecharger?
Sick96Stang
621
Gilbert, Arizona
Nov 30, 2004
#11
  • Nov 30, 2004
  • #11
Yea it was happening before the densecharger but it seems like it got worse after I installed the densecharger like it started doing it more. The check engine light has been weird. At first when I put on the O/R H-pipe and the MIL's it wasent on then 2 weeks later it came back on, and it was reading that it was an o2 sensor so I replaced that o2 sensor and then the CEL stayed off for anohter 2 weeks or so then came back on.
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • Gulftown980x
  • Jul 29, 2026
squeak93
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
