ported AFR205 393 NEED CAM this week
black95cobra
89
Pensacola, FL
combo is 393 dished pistons making 10.5:1 comp
AFR 205's milled to 49cc hella ported
TFS R intake
36# injectors
ProM 80mm MAF
AFM powerpipe
75mm TB
Mac longtubes 3" collectors
tremec 3550
3.55 in the rear etc etc.
I am a big fan of the comp cams xe286R made 555 Hp and 516 ft lbs on a 393 with your heads (not ported) peak hp 6600 and peak torque 4900. With 450 ft lbs and 300 hp at 3500 rpm :D make for a mean ass car! Nice combo :nice: mind you it was carbed but whatever you get the idea. With a 418 and the same cam and heads it made 621 hp and 562 ft lbs with 12:1 comp.
cam specs are
lift .614/.621 and 248/254 duration at .050 lift
maybe trickflow stage III(236/248-.574"/.595"-110 lsa)rpm range for a 302 would be 3200-6800.i personally don't know if the extra cubic inches will effect in anyway
order from summit(159.95) have it by this weekend.
just my .02
49cc, man you milled them pretty good. If you need one this week you are limited to a stock shelf cam and that may not yeild you the best end results.
Call the cam manufactor to see what they reccomend for a stock shelf cam, COMP has always had good tech service. Otherwise I'd get a custom, but you'll have to wait a few weeks.
