porting , polishing intakes
  • Thread starter Thread starter sorrell
  • Start date Start date Sep 1, 2005
sorrell
  • Sep 1, 2005
Just bought upper and lower typhoon intakes and was wondering if any one where I could get some info on porting polishing , inside of runners a little rough
txstang84
1,639
42
69
Tuscola, tx
Sep 1, 2005
  • Sep 1, 2005
i think theres a tech article on MM&FF's, or 5.0's website for that...
maverick0716
3,924
Chilliwack, BC, Canada
Sep 1, 2005
  • Sep 1, 2005
From what I've heard polishing intake ports is not a good idea. There needs to be some velocity to an intake charge to get the fuel mixture right.....or something
Daniel50
716
Discovery Bay, CA
Sep 1, 2005
  • Sep 1, 2005
go to tmoss website. he has an article on how to do it
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Sep 2, 2005
  • Sep 2, 2005
link in my signature..........
vikingpower
656
CWU Ellensburg, WA
Sep 2, 2005
  • Sep 2, 2005
I used a cartridge roll kit and some porting carbide bits I got from Summit, its pretty easy just time consuming. Make sure you get the longest mandrels you can find to reach all the way in the runners. Also, one of the runners in the lower has a bad kink in at the bottom, I used my carbide bits to reshape it by removing a some material. Thats about all the port work it needs, then just polish the runners to your level of satisfaction. I dont remember which runner had the kink in it, but its pretty obvious when you're examining it. I also did a lot of work on the TB opening becuase I bought a 75mm TB to go along with the manifold. Overall, works great!
jrod95gt
1,096
Katy, TX
Sep 6, 2005
  • Sep 6, 2005
seems like I heard that for carb intakes because the fuel and air travel through the intake together, so you want it to tumble around a bit and get mixed together. In an EFI manifold, the fuel isn't introduced until right where it meets the heads. I would think smoother is better for airflow.
Also, I don't think the smooth walls would have a great effect on velocity(aside from turbulent vs. laminar airflow; that could be a bigger difference than I thought), that has more to do with the actual size of the runners, yes?
maverick0716
3,924
Sep 6, 2005
  • Sep 6, 2005
That makes perfect sense. I was thinking carbureted intake
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Sep 6, 2005
  • Sep 6, 2005
You alos don't want the wet carb airlfow to encounter much obstruction as that tends to cause the fuel to puddle out of the airflow - i.e. when using a smaller carb (600-650cfm) on a 347 and an open or dual plane intake - use a open spacer under the carb to give the air/fuel a larger turning radius to avoid the air/fuel from hitting the intake bottom causing fuel puddling. If using larger carbs, the velocity throught he venturies is less and the issue is reduced.
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
T
Digital Tuning Hello OBD2 problem
  • TNmach1
  • Sep 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 18, 2026
TNmach1
T
Resolved 1999 cobra removed lower intake manifold to crossovertube
  • hvcobra99
  • Sep 6, 2026
  • SVT Tech Forum
SVT Tech Forum Sep 6, 2026
hvcobra99
Engine Forged flat top pistons from 5.0 fit a 351 build?
  • PonyGTrider
  • May 22, 2025
2K
Fox 5.0 Mustang Tech Feb 1, 2026
PonyGTrider
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
