Posi Kits
  • Thread starter Thread starter Sixty Nine Mach
  • Start date Start date Sep 29, 2004
Sixty Nine Mach
10
Long Island
Sep 29, 2004
  • Sep 29, 2004
So i finally got my loose lifter fixed, got my headers and x-pipe done and got my shifter to work properly, but now i have two more problems. One being the fact that i do the one wheel peel, so if anyone has any ideas about a posi kit without breaking my wallet that would be great. the second problem is my car shuts down for no reason now, and when i go to restart it nothing happens, nothing at all. my lights don't work nothing and the car wont turn over. after a couple of minutes with the hood up and messing with wires it will start. so if anyone has any ideas about that one let me know.
Stang_1973
565
9
38
San Antonio, Tx.
Sep 29, 2004
  • Sep 29, 2004
For the power loss, check your starter selenoid, it might be getting really hot and burning out. This happened to me and went away when i changed the selenoid. As for peg legging, I want to see what someone else posts because i am in the same situation as you.
69PaleHorse
264
Ventura County, CA
Sep 29, 2004
  • Sep 29, 2004
For your electrical problem I would seriously recommend checking and double-checking your ground wires. Make sure that none of them are missing and all have good, metal-to-metal connections.
This sort of thing happened to me not too long ago and it turned out I was missing two ground wires. Just adding the ground wires fixed a whole mess of problems.
KillerKittyCat
150
Hammer Down - Behind The Wheel
Sep 29, 2004
  • Sep 29, 2004
I agree with the starter relay being the problem.
Rear ends are not that cheap. You can go to a Spicer distributer and buy the parts but without the tools and knowledge.........
At a shop, Traction-Loc should be around $600 all the way up to the Auburn at $900.
bnickel
5,640
lubbock, texas
Sep 29, 2004
  • Sep 29, 2004
assuming you have a 9" you can get a used traction lok center section from most all ford pickups until 86, in about any wrecking yard and in most any gear ratio if you look hard enough. most of the trucks will have 31 spline axles, but you can get 28 spline side gears from most axle shops and have them swapped in, while you're at it get the the unit rebuilt with new bearings and clutches and you should be good to go. price wise you're probabaly looking around ~250-450 bucks for everything depending on how much you can the chunk for initially and who you have do the work
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Today at 8:00 PM
Blackhawkxx
R
Interior and Upholstery Interior roof adhesive removal HELP
  • Riley Barth
  • Jun 22, 2026
Fox 5.0 Mustang Tech Jun 23, 2026
Riley Barth
R
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Rear Decklid Finish - Lost Gloss
  • 120rir
  • Oct 1, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 1, 2026
120rir
