  • 2.3L (N/A & Turbo) Tech
Possible coil problem...
  • Thread starter Thread starter babybudistmonk
  • Start date Start date May 21, 2009
babybudistmonk
70
Rockford, MI
May 21, 2009
  • May 21, 2009
Hey Guys,
I was wondering if there was a quick simple way the check the coils on the dual spark engine. I think those may be the problem, but would like to know for sure before i spend $100 at autozone for new. thanks!
Tony
Dr_EluSivE
2,155
Central Illinois
May 21, 2009
  • May 21, 2009
You can swap them, the exhaust side only fires at certain times, the car will run fine on just one pack. If you swap them and it runs ok, then you only have to replace the one.
Dr.
D
Dan'l
1,539
wisconsin
May 21, 2009
  • May 21, 2009
tach?
Does your tach still work?
Dr_EluSivE
2,155
Central Illinois
May 24, 2009
  • May 24, 2009
wow i havent seen you in years! how are things
Dr.
babybudistmonk
70
Rockford, MI
May 24, 2009
  • May 24, 2009
yeah, the tach still works. what do you have in mind?
babybudistmonk
70
Rockford, MI
May 27, 2009
  • May 27, 2009
another quick question, which coil fires the main ignition and which is for the exhaust? thanks
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 10, 2026
gkomo
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
