  • SN95 4.6L Mustang Tech
Possible lean Condition
  • Thread starter Thread starter Ram5773
  • Start date Start date Dec 20, 2006
R
Ram5773
66
Melbourne, Florida
Dec 20, 2006
  • Dec 20, 2006
If you guy's can give me some advice please, I bought a used Densecharger with a Pro m 85mm Mass that is calibrated to work together as a kit to go with the stock injectors.
Now my question is do you think that kit will cause the car to run lean?
I also have a Superchips max micro tuner installed on the car too. This could also be a lean possibilty too.
Could these two together cause serious lean problems?? I have been running the set up for two days and the car runs great, No Cel light. I understand that the stock Mass meter is probaly good for what is done to my car but I bought the Denscecharger kit for a song and I would like to use both parts. Should I remove the Pro M a put the stock mass airflow back or just remove the tuner? I have no detenation that I can hear?
How much will the adaptive stratagy cover if it is lean fuel wise?
I still have a stock throttle body and plenum but there is a accufab set up sitting under the tree as a present . My other mods are just a catted h-pipe and cat back. I know that I need to get the car to be data logged but right know I'm christmas POOR
I don't want to screw my car up by possibly running it lean. Guy's what's your thoughts. Sorry for the long and possibly confusing post
Thanks Ram:SNSign:
the98stang
2,408
Clovis, CA
Dec 21, 2006
  • Dec 21, 2006
Get it on the dyno if you are so concerned about it running leaning. If you have an intake and no other mods, your car will run slightly lean. Exhaust would balance it out.
twogts4us
4,188
12
79
Dunedin, FL
Dec 21, 2006
  • Dec 21, 2006
If it were me, I'd err on the side of caution and put the OEM MAF back on until you can get on a dyno.
OEM MAF: -1 HP
Dyno time/tune: $200
Blowing the engine because you chose not to put the OEM MAF on: Priceless
(Tongue in cheek here guys, but there's some truth to this!)
(Also, be aware, just because you don't hear detonation, doesn't mean you aren't lean.)
jstreet0204
939
Winston Salem, NC
Dec 21, 2006
  • Dec 21, 2006
The ProM Maf is most likely making it rich, but never change the MAF without a tune. Attached is a comparison of the curves of a ProM-19 to a stock MAF. Notice that the same voltage on the ProM indicates less air flow than the stock MAF. This means, that the air actually coming in through the ProM is less than what the EEC thinks is coming in, so the eec will add more fuel.
The ProM is the green line.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
T
Fuel Looking for a little guidance
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 12, 2025
T
  • Locked
Digital Tuning A9l issue or something else
  • Tufgriz
  • Sep 11, 2025
Fox 5.0 Mustang Tech Sep 11, 2025
G
In expensive ceramic coating
  • gray owl
  • Jul 12, 2026
  • Mustang Sound & Shine All
Mustang Sound & Shine All Aug 18, 2026
NotaVegetarian
N
