Post all your annoying things wrong with your car.
ive had my car since i was 16 and have driven it a total of about 3 months in 5 years, i need to finish my motor, do a totally new suspension, paint job, brakes, tires, interior, pretty much everything needs done but all that is my fault as well because i decided to tear everything apart to restore the darn thing :S then with my svo i got drunk one night and had to let a buddy drive it to my place and since there was no 93 octane pumps around that area i put 90 in it and was gonna take an easy with boost till i got better gas, well my buddy is a non car guy type and decided to top it out while driving it to my place and burned a hole in my number three piston from all the detonation cus from what i was told by the passenger they cruised full throttle at 150 for quite a long time and he said he heard lots of weird noises from the engine bay and they only slowed down cus it started misfiring real bad, but the first thing he said to me when i started it the next day was that it was running like dog poop and when i told him later when i pulled plugs and found aluminum melted on the tip of one what the deal was all he said was that it wasnt his fault cus it was prolly gonna blow up anyhow and nothing i say to him will convince him he caused it cus he knows nothing about motors and thinks im full of **** sorry bout the long rant just hadta get it off my chest :mad:
I get just as wet in the rain with the top up as I do when it's down
Cam and 3:73's are just sitting in my shop
speedo cable squeeks
gangsta lean in BOTH seats
carpet is cigarette burnt and stained
pass side door window is missing guide bushings so it goes up crooked
pass side door lock actuator seized won't unlock, can't get it open to fix it.
leather seats are torn/worn to crap
cruise doesn't work
a/c doesn't blow cold
vibration in overdrive
need windshield
ashtray door doesn't work... (console is worn out so to fix door I have to replace the whole console)
weatherstripping all around has decided to do it's own weight reduction
fuel pump relay won't turn off
wet differential cover (always)
panel dimmer switch has a "sweet spot" that it will work at... barely.
My dad keeps telling me how cool is cadi cts is and how it tells him the temp outside... I tell him, mine tells me the temp outside too... if it's 50-60 the dash squeeks, if it's 60-70 the top rattles, if it's 70-80 the tranny over heats, etc... just as good as a digital gage in the visor :D
1989 gt 5speed
outer door and window mouldings(all) faded and ugly as hell
needs alignment or something else to fix sloppy ass steering
needs shocks/struts and springs
shifter vibrates alot at higher rpms
clutch quadrant(fixing)
smells like gas
all weatherstripping also is crap
small oil leak (oil pan looks like its dinged up so maybe new oilpan?)
heater core bypassed (car runs fine but is this bad?)
has crappy old reflective tint(previous owner)
maplight busted
ashtray door busted
e-brake has to come up high just to hold the car
new brakes
glove box latch broken
shifter boot has hole in it
gangster lean on seats
replacement rear view mirror likes to fall off sometimes
blown speaker
cheap ass paintjob, complete with sagging rear cobra bumper with a half inch gap between the bumper and car.:nonono:
i second the "dont go with cheap when it comes to body work and paintjobs"
thats all i can think of. for right now.
1. Mufflers hitting the frame...
2. Crappy Steering
3. Crazy Bump Steer
4. Thermostat Housing Leak...
5. Bad 3rd gear syncro (I think T5's come like this from the factory)
6. Tailpipes melting the fuel line...
7. Stupid PCV!
8. Drum Brakes
9. Doors Leak
10. And it Always needs gas :D
1.shreds the belt ever 100 miles or so im on the 5th 1 since the rebuild.just havent had time to really get it fixed.
2.idle surge mostly while at a stop light.but runs great on the highway.
3.needs paint and some bodywork.and need to repaint the pony's or get my monsoons poder coated.
4.leaky pass. side axle seal.
5.ac doesnt wor(its gone when i get the ac delete bracket.
6.have a edge converter pa valve body,sub frames the konig rims and some other stuff no on the car...
Map light doesn't work
ash tray door spring is jacked
cruise control no workee
front headlights hazed over
missing fog light lens
hole in shifter bezel from previous alarm LED
some jack ass bumped me at a red light last week and chipped paint off and left 2 nice bolt head impressios in skirt
console armrest latch broken
leaky power steering hose
turbines
needs new shocks and struts
and no money to fix any of the above.
87 coupe
-it doesnt run
-its on jack stands
-needs a motor
-needs a tranny
-needs a wiring harness
-needs a computer
-its already a money pit and it hasnt moved an inch for 4 months:shrug:
positives
-it gives me incentive to go to work
-not really any rust except for the bottom of the doors and the trunk lid.
-should be running by summer:)
1990 Gt 118K Miles
-Interior-
-Previous owner took out Carpet, Rear Seat, And Seatbelts
-Map Light Doesnt Work
-Previous Owner Disconected Radio for Christ Sake
-Exhaust Rattles on Frame
-Power Door Locks Broke
-Heater Core Broke
-A/C taken out for some Reason
-Voltage drop at idle
-Needs new glovebox
-Smells like Antifreeze occasionally
-Very Loud sqeueks and rattles
-Engine-
-Small puddles of antifreeze everyday
-Powersteering Pump Zings
-Lifter ticking /knoking noise sometimes
-oil temp gets hot in 1st and second gear
-Needs to be painted
-Reverse is Gone
-Grinds into second rarely
-Exterior
-Miniscule dents Everywhere
-Paint faded form previous owner letting sit in sun on driver side
-Rear hatch window trim is ugly
-Wax stuck in those hard spots
-Front bumper paint chips
-Windshield is hammered
-Needs fog lights and bracket
And my Throwout bearing is squeeling like a Mo Fo
Car still looks Good Though!
-Crank in rear corner of bumper
-gangsta lean in one seat (have new ones just no time to put them in)
-weather strippin on doors
-ashtray door
-repaint black mirrors and moldings, headlights (puttin the new ones on in a week or two)
-needs subframes
- wrost is 3 rust bubbles starting in 3 small areas, just needs to sand the small spots and repaint (doing it when i get the car up here at school in buddies driveway. I HATE RUST and NE!!!)
hmmmm lets seee .....
its a sunroof car ... and the sunroof is junk
the sunroof leaks on my 00gt seats
p.s rack is gone
need new tie rod ends
still have to fix cowl panel where hood flew up
rip in the front bumper cover
oh and my number one thing is that its a gt car and not a coupe ....
but on the upside .... it keeps me occupied from working on it all the time .... and the chicks love it woop woop
