  • 1994 - 1995 Specific Tech
Post your pushrod length.
  • Thread starter Thread starter 5spd GT
  • Start date Start date Oct 5, 2007
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 5, 2007
  • Oct 5, 2007
Okay, here is what I want to know
- Stock or Decked Block
- Heads Used (Please note if milled or shaved)
- Headgasket compressed thickness
- Cam Used (If custom, just give basic specs - lift/duration)
- Roller Rockers (1.6, 1.7, or 1.72)
- Pushrod Length (Give me the length with your combo).
- Does it ride in the center of the valve?
- Have you had any problems?
I'll start:
AFR 165's (not milled)
FTI Cam (.560/.556 - 224/224)
.039"
1.6
6.250" Pushrod Length
Yes
No, going on over 30,000 miles.
If you know the installed height of your springs, if aftermarket, let me know as well
302 or 351 It doesn't matter...
I'm wanting to get a general synopsis of what lengths typically go with what combination. However, measuring is best, but let's see what you guys are running
List if your engine block has been machined (decked/shaved) please.
Thanks!
earleys94gt
1,223
Ashley, Ohio
Oct 5, 2007
  • Oct 5, 2007
- Stock Block.
- E7's with 1.96/1.60 valves, milled .0010" (I think).
- Steeda 19 cam.
- Stock Rockers.
- Stock Length push rods (Ford Racing).
- Yes?.
- Put 200 miles on it, I have some white smoke. Don't know if it's lean or leaking
something. Also think I have a pinging issue .
R
RAD
167
  • Oct 5, 2007
Not too long .... but is thick , if that counts.
had to say it. sorry
blksn955.o
3,263
st.louis mo 314
Oct 5, 2007
  • Oct 5, 2007
-DSS shortb- I was told it was 0 decked to the pistons but not how much
-GT40 iron heads milled 60 or so shock: )
-fel-pro 1011 IIRC .039 or .04x compressed?
-TFS1 cam
-Stock rockers but do plan on going with a roller 1.6 sometime
-6.150
-center with a short travel patt.
-none I can tell
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 5, 2007
  • Oct 5, 2007
Stock (Explorer) shortblock, TFS Twisted Wedge heads, TFS 1.6 Roller rockers, TFS stage 1 cam, Fel-Pro 1011-2 head gaskets, 6.750" pushrods. Used a modified hydraulic roller lifter and an adjustable pushrod to come up with that length.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 5, 2007
  • Oct 5, 2007
David
pr length is 6.250
block is oem
no milling or cutting
AFR 165's 58cc stud mount
Scorpion 1.6 stud rr's
I've had no probs
Here is a pic of the roller travel across the valve tip
Grady
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 6, 2007
  • Oct 6, 2007
Grady, that sounds familiar That is what Ed sent me with my combo...
Thanks for the pic, looks good!
Thanks to everyone.
I want to say real quick, we all should realize that measuring is the best method for best valvetrain geometry and longevity, but many combinations can benefit from the same length pushrod.
So I am not trying to imply that 'not measuring' is what should be done, but I am just trying to get a ballpark figure for some to start from.
I know the TFS and Holley kits come with pushrods that 100's have had no problem with, and they did not measure.
It is just for my own personal info, so thanks for helping
Engine Pushrod Length?
  • foxbodyclark
  • Jan 25, 2025
Fox 5.0 Mustang Tech Jan 25, 2025
limp
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
E
For Sale 1989 LX Notch 410ci 85mm turbo 8 pt cage 9" rear end
  • EightyNineFive
  • Aug 22, 2021
5K
Fox Body Mustangs For Sale (1979-93) Jun 18, 2022
Freakinstang
F
