Power Adders
  • Thread starter Thread starter 93blown50
  • Start date Start date Sep 6, 2009
9
93blown50
15
  • Sep 6, 2009
Hi guys right now i have a paxton supercharger on my 93 gt mustang it is time to rebuild it and i am considering taking it off and going with some other bolt ons could you please suggest to me which would be the most beneficial for my car the car is stock other than exaust the supercharger is putting out about 5lbs of boost i would like to make some of the power back that i will be loosing any help would be appreciated.
earleys94gt
1,223
Ashley, Ohio
Sep 6, 2009
  • Sep 6, 2009
Gears
Cam
Heads
Intake Manifold
Just a few places to start.
Doing some research to decide what would be the most benificial to your driving style would be the best way to decide what to do first.
bentley429isBAC
922
188
84
CT
Sep 7, 2009
  • Sep 7, 2009
What supercharger is it and what is your budget
F
FoxGT87
5 Year Member
Aug 1, 2009
1,518
St.pete FL
Sep 7, 2009
  • Sep 7, 2009
what are you doing with the old paxton and kit?
T
time only
461
Miami,FL
Sep 7, 2009
  • Sep 7, 2009
earleys94gt said:
Gears
Cam
Heads
Intake Manifold
As early94gt suggested,those bolt-on,opening up the intake and gear will build you a solid base for your Mustang. Your Mustnag hp and tq gain should equal if not more then the 5psi you are getting from the S/C. But that is costly too. 100 shot of Nitrous is cheaper.
But it all come down to which direction you wants to go and how much you wanted to spend. If you keep the S/C and do those bolt-ons down the road,you will have a easy 11-12 second Mustang.
lincoln+ford
195
  • Sep 7, 2009
earleys94gt said:
Gears
Cam
Heads
Intake Manifold
Excatly what he said.Sell that blower set up i hate when ppl put blowers at such a low psi on a stock motor?
9
93blown50
15
  • Sep 7, 2009
The supercharger is a novi gss 30020 and if i decide to take it off it will be for sale. I drive the car on the street alot and it does not see that much track time so i do not want to take it to the point of being unstreetable. I also have another question how many miles can you usually look for on a supercharger system like this before having to rebuild.
K
Kevins89notch5.0
5,864
Sep 7, 2009
  • Sep 7, 2009
Have you driven a stock 5.0 with a blower on it? I had a stock pullied S-Trim on my 89 with only gears and exhaust. It made 7-8psi at nearly redline,, but around town I barely saw much boost at all. However, to say the wasn't a completely different beast would be a lie. I don't think I will ever own another 5.0(except a show car like my 93 Cobra) without a S-Trim on it. It is the perfect setup. I could still get 25mpg on the highway, and run high 11s on slicks.
D
4.6L 4v motor swap
  • DangStitches
  • Jul 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 29, 2026
squeak93
F
Engine 1988 Foxbody idle issues
  • fernandosgarage55
  • Apr 28, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
AeroCoupe
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
