Power Lock Problem
cj50
new jersey
My drivers side power lock would lock and unlock my passenger side only so I replaced the actuator in the drivers door and now the drivers side will lock and unlock both sides except now the passenger side button will not work . Please help. Thanks
sorry if this is not posted in the right place. Im new to this and my computers acting up.
Possible switch problem...
Simple first step; remove the passenger side switch and spray it down good with electrical parts cleaner available from the auto parts store or Radio Shack.
Wiring diagram:
power-door-lock-wiring-gif.73204
Reactions: Doc Word
check the switch with a test light to see if you have power when you depress the button. Often those buttons go bad after years of use. 5 minute replacement. That and check the wiring in the door as you may have inadvertently pulled a wire off when you were in there. Check all the wires going into the bottom of the switch to make sure they are seated.
I'll give it a shot. Thanks again!!!
