Power Locks
  • Thread starter Thread starter rd
  • Start date Start date Mar 19, 2006
rd
3,316
63
109
Ocean Springs MS
Mar 19, 2006
  • Mar 19, 2006
My 89 Lx has a power door lock problem. The drivers side switch will lock both sides, but wont open either. The pass side switch opens and locks both.
I changed lock motors on the driver side, made no diff. I had a pass side switch, so I swapped it. No change.
I had the drivers switch out, cleaned the contacts. No improvement.
Both the spare and orig lock motor work both ways with 12 v to them.
My next thought is to replace the drivers switch.
Suggestions please.
Thanks.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Mar 19, 2006
  • Mar 19, 2006
You should have tested if the actuators were getting power first. That is most likley your problem. Either that or the wiring. Do you own a test light?
rd
3,316
63
109
Ocean Springs MS
Mar 20, 2006
  • Mar 20, 2006
Thanks. Sorry, I did not mention that. I have a meter and test light.
There is power to the drivers switch, and the switch seemed to test ok for continuity, but no, it does not seem to send power to either lock for the unlock mode.
I tested at the drivers actuator connector, with the meter and did not seem to get power in the unlock mode.
I'm thinking its the switch, although it appears that power for that mode goes through the pass side switch and actuator on its way to the drivers side motor.
Wiring? Switch? Poltergeist?
GearHd6
459
Ashford, CT
Mar 20, 2006
  • Mar 20, 2006
The wires from the drivers side switch go all the way over to the passenger side lock and then back to the drivers side. Those wires are routed under the dash but up near the windshield. If you pop the speakers out of the dash you can see where the wires run and you can probe them there to check for power.
HISSIN50
34
129
Mar 20, 2006
  • Mar 20, 2006
On my 88 GT vert, I accessed the power lock connectors at the top of the driver side kick panel (just a little lower than GearHead from the sound of it).
GearHd6
459
Ashford, CT
Mar 20, 2006
  • Mar 20, 2006
Yeah the plug is over there, you're right. But I dont think theres one over on the passenger side in that location so I just probed the wires behind the speaker to make sure there wasnt a short somewhere between the driver and passenger side under the dash. My problem ended up being that someone butchered in an alarm that must have had a key ring actuated lock/unlock button and the wires were cut.
HISSIN50
34
129
Mar 20, 2006
  • Mar 20, 2006
Ah so, I didnt even think of checking things on the pass side (for wiring issues' sake)
That sucks about your experience with goofy wiring fixin. IIRC from my install, I could get the connector for both actuators, and one for driver-side-priority on the driver side alone (at those connectors).
Anyhow, I see what your point was about checking things through the speaker hole or at the switch on the pass side - nice point!
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
1989 gt both doors wont lock or unlock help.
  • 1989 mustang gt
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 22, 2025
manicmechanic007
