power mirror help.
  • Thread starter Thread starter skunk21
  • Start date Start date May 23, 2007
skunk21
1,203
Taxachusetts
May 23, 2007
  • May 23, 2007
I have a 91 that I just picked up and i'm working out the bugs. I did some searching but couldn't get what I was looking for.
I'm having problems with both mirrors. when I operate the switch the drivers side will go up and out but not in or down. the pass will go up but I can hear the motor spinning to bring it in but the glass isn't moving. the pass will not go out or down. are the motors inside the mirrors. what do you guys think switch or switch and mirrors. thanks
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
May 23, 2007
  • May 23, 2007
I would have to go with mirrors
93 LX
3,081
Norwalk, CA.
May 23, 2007
  • May 23, 2007
Could be 2 problems. You could test the switch or just get a new one. They arent that much but the passanger side sounds like a mirror issue. Yes the moters arelocated inside the mirror but there are plastic control rods inside that break. If the mirror is hit for some reason these rods can and do break. Be careful removing the glass. The mounting for this glass can break easily. To remove the motor unit you have to move the mirror left and right to get a screw drive inside. This is where you can break things so be very very careful!
Allen
trbkrb
1,976
Houston, TX
May 23, 2007
  • May 23, 2007
You might want to take the mirror switch apart and clean it inside. When I installed my power mirrors, they didn't work all directions, but worked when I applied power directly to the mirrors. After cleaning them up, they worked fine for a while. I think I spilled a drink on it since they are acting up again. As for the one mirror that you hear running, it is a mirror problem.
Good luck on it!
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
V
Paint and Body Problem with 1985 GT T-Top outside mirrors
  • Vatchy
  • Sep 9, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
Vatchy
V
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
