  • 2005 - 2009 Specific Tech
Power Pack
  • Thread starter Thread starter tungstang
  • Start date Start date Jul 25, 2006
T
tungstang
  • Jul 25, 2006
Has anyone tried the Ford Power Pack that is offered in the Ford Racing Accessory catalog (mufflers,cold air,and sensor)?
red05bullitgt
861
Pittsburgh, PA.
Jul 25, 2006
  • Jul 25, 2006
tungstang said:
Has anyone tried the Ford Power Pack that is offered in the Ford Racing Accessory catalog (mufflers, cold air,and sensor)?
Actually, I don't know if your aware of this or not, but the Ford Power Pack 1 which consists of the cold air kit, flash tuner and axle back exhaust are actually designed for Ford by Steeda Autosports..Steeda and Ford share what is called, technology transfer program which consists of sharing engineering specifications, calibration and performance parts..Basically in a nutshell, the Ford power pack cold air kit in reality is actually Steeda's with Ford's name on it..Check out Steeda's website when you get a chance and you'll see for yourself that their parts look exactly the same..In fact my cold air kit will be arriving hopefully in the next 12 hours from Steeda..However, if you want some friendly advice, get your cold air kit and tuner from Steeda directly, because that sensor or pro cal tool that's included in the Ford power pack ?? is really not a real flash tuner, all Ford's pro cal tool will do for you, is only calibrate your factory sensor to the new intake housing and re-map the fuel curve which just requires you to use premium fuel.. Other than that, you really won't notice any real perfomance or HP gains, in fact you can't even make adjustments with their pro calibration tool at all..So believe me, You'll see much more of a difference and be much happier if you order the SCT X-Cal II flash tuner along with your cold air kit direct from Steeda as a combo..Anyway here's the website for Steeda..www.steeda.com Plus you can also call Steeda, they also have a toll free number on their website for tech support.. Ask to speak to Jason, he'll make sure that all your needs are taken care of and will take the time to make certain that all your questions are answered, as well.. Anyway, I'll let you know when I have the kit installed and how everything works..In the meantime, let me know what you think and what you decide.. Correction, just the FRPP CAI is designed by Steeda Autosports, the axle backs are designed by Borla
T
tungstang
  • Jul 26, 2006
red05bullitgt said:
Actually, I don't know if your aware of this or not..But the Ford Power Pack 1 which consists of the cold air kit, flash tuner, and axle back exhaust..Are actually designed, for Ford by Steeda Autosports..Steeda and Ford, share what is called, technology transfer program.. Which consists of sharing engineering specifications, calibration, and performance parts..Basically, in a nutshell..The Ford power pack cold air kit, in reality is actually, Steeda's with Ford's name on it..Check out Steeda's website, when you get a chance and you'll see for yourself, that their parts look exactly, the same..In fact, my cold air kit, will be arriving hopefully, in the next 12 hours, from Steeda..However, if you want some friendly advice..Get your cold air kit, and tuner from Steeda directly, because that sensor or pro cal tool, that's included in the Ford power pack ?? is really not, a real flash tuner..all Ford's pro cal tool, will do for you..is only calibrate your factory sensor, to the new intake housing and re-map the fuel curve, which just requires you to use premium fuel..Other than that, you really won't notice any real perfomance or HP, gains..In fact, you can't even make any adjustments, with their pro calibration tool, at all..So believe me, You'll see much more of a difference and be much happier, if you order the SCT X-Cal II flash tuner, along with your cold air kit, direct from Steeda as a combo..Anyway, here's the website for Steeda..www.steeda.com Plus you can also call Steeda, they also have a toll free number on their website, for tech support.. Ask to speak to Jason..he'll make sure that, all your needs are taken care of and will take the time, to make certain that all your questions are answered, as well.. Anyway, I'll let you know when I have the kit installed and how everything goes..In the meantime, let me know what you think and what you decide..
50Dreamer
688
17
38
CT
Aug 30, 2006
  • Aug 30, 2006
Looks like that dude was just throwing comma's where ever he wanted....wtf
JTGrant
775
GA
Aug 30, 2006
  • Aug 30, 2006
make your own power pack
310stanger
170
  • Aug 30, 2006
what kind of pricing is on that power pack? i would probably jus pick the cai, buy ford motorsports gears, and get a tri ax myself. then get myself either the predator or the sct. i have a feeling if you shopped around on those following parts youd be able to beat what ford racing and steeda are selling theres for as a kit. ques, does that mean ford racings mufllers for the 05/05/07 mustang gts are steeda mufflers?
red05bullitgt
861
Pittsburgh, PA.
Aug 30, 2006
  • Aug 30, 2006
Well wtf.. if the comma's bother you so damn much, just ignore them .. Never mind, I went back and took most of the comma's out
red05bullitgt
861
Pittsburgh, PA.
Aug 30, 2006
  • Aug 30, 2006
The Ford Racing Mufflers, are made by Borla
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Teflon O-ring for power steering
  • revhead347
  • Feb 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
revhead347
