Power point failure???
CTGrey02
1,403
Bristol, CT
Have any of you guys had a power point fail on ya?? The one near my shifter decided to quit on me a couple weeks ago. Any ideas? Anyone know which fuse they are? The one in the console works fine too.. just the front one.
They are called "power points" by Ford.
The one just behind the shifter is protected by fuse 2.1 (20 Amps). The one inside the console arm rest is protected by fuse 1.9 (also 20 Amps). Fuse 2.1 is located under the dash, in the row that only has 5 locations (the other 6 rows have 6 locations). It is the fuse farthest from the circuit breaker in that row. Fuse 1.9 is in the panel located under the hood, in the column next to the relays.
