power problem with engine?
  • Thread starter Thread starter chr1s11575stang
  • Start date Start date Sep 18, 2007
chr1s11575stang
64
Orlando, Fl
Sep 18, 2007
  • Sep 18, 2007
1990 gt when i push on the gas it doesnt seem to have the power that it normally does. It almost sounds like a flutter when you hit the gas. is that the exhaust of could something be wrong like the plugs, wires or something else with the engine?
bloopbloob
578
Alberta
Sep 18, 2007
  • Sep 18, 2007
i'll probably be just the first of many to suggest you dump the codes first. your description doesnt help much either. my first guess may be something with your egr system, but you dont have enough info to really tell.
Flavadave4
1,044
21
49
Utica, NY
Sep 18, 2007
  • Sep 18, 2007
A simple tune up is a great place to start, new plugs, wires, cap and rotor!
chr1s11575stang
64
Orlando, Fl
Sep 18, 2007
  • Sep 18, 2007
what other kind of info would you need
bloopbloob
578
Alberta
Sep 18, 2007
  • Sep 18, 2007
well i don't get what "it almost sounds like a flutter" means. what is sounding like a flutter? what does a flutter sound like? where is the noise coming from? any other noticeable symptoms? when do you lose power? full throttle, part? high rpm/low is car stumbling/bucking....? etc., anything else?
chr1s11575stang
64
Orlando, Fl
Sep 18, 2007
  • Sep 18, 2007
ok b flutter i mean when i floor the gas at any speed it almost hesitates/takes it time reacting to me hitting the gas. There are no other symptoms or anything and this just started on my lunch before that it was fine. I guess it can be considered a slight hesitation. all fluids are fine. This happens at any spped i am going. Starting out and while the rpms are up.
Flavadave4
1,044
21
49
Utica, NY
Sep 18, 2007
  • Sep 18, 2007
Sounds like you just need a tune up, do that and set the base timing between 12-14* (if you run 93 octane) It will wake your car up. I had to do the same when I first got mine!
Usually you can drive it out of the hesitatiion, it really only happens when the motor is under load.......but its a pretty inexpensive fix.
chr1s11575stang
64
Orlando, Fl
Sep 18, 2007
  • Sep 18, 2007
ok thanks i will try all this when i get home tonight...
bloopbloob
578
Alberta
Sep 18, 2007
  • Sep 18, 2007
+1 on the tune up and timing.
might be a good idea to also check your tps? only takes a couple minutes to set it.
87foxstang
Cromwell, CT
Sep 18, 2007
#10
  • Sep 18, 2007
  • #10
yea i would suggest a test of the TPS as well
chr1s11575stang
64
Orlando, Fl
Sep 18, 2007
#11
  • Sep 18, 2007
  • #11
is there a good book out there that explains all the technical stuff? Or is it more learning as you go. I ve only had this for like 2 weeks now so I was just curious.
Flavadave4
1,044
21
49
Utica, NY
Sep 18, 2007
#12
  • Sep 18, 2007
  • #12
Keep reading on here and you will learn alot.
www.corral.net is a great place for tech.
I would suggest a Chiltons manual, helps with the step by step stuff and gives you pointers along the way.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 18, 2007
#13
  • Sep 18, 2007
  • #13
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
1970 Mach 1 voltage regulator
  • 70ivygreen
  • Oct 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 27, 2026
Mcmahst
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
  • brandyn200
  • Jun 20, 2026
AeroCoupe
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
