  • SN95 4.6L Mustang Tech
Power Steering & Brakes
  • Thread starter Thread starter laserbrn
  • Start date Start date Dec 4, 2007
L
laserbrn
24
  • Dec 4, 2007
I have a 2000 Mustang GT 4.6L. All of the sudden my power steering and brakes are acting up. The belts are all turning, but I have no power steering and the brakes are hard as a rock. The brakes seem to stop the car but they don't have the natural feel. I was thinking vacuum leak, but I just can't seem to resolve this issue.
Does anyone know what might cause both of these systems to fail at the same time?
Superhereaux
chicks make me feel inadequate
538
South Texas
Dec 4, 2007
  • Dec 4, 2007
Ford uses whats called hydro-boost instead of a conventional (vacuum) brake booster. the power steering pump creates the pressure needed to provide the brake assist as opposed to engine vacuum
check the power steering fluid level and check for leaks around the booster unit itself. you're looking for a red puddle since it uses ATF. have you had any work done to the vehicle lately?
L
laserbrn
24
  • Dec 5, 2007
No. No work done to the car recently. I will check on it tomorrow and see if I see any fluid leaking. Would replacing the power steering pump solve this problem? I suspected it was a hydroboost system for the brakes after reading some more info online, but don't quite understand this type of system.
Mustang5L5
Mod Dude
Feb 18, 2001
43,368
18,115
224
Massachusetts
Dec 5, 2007
  • Dec 5, 2007
Yes if the power steering fluid is low due to a leak, it would cause both problems.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 9:17 AM
keel
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
