Power Steering & Headers
  • Thread starter Thread starter wakeboardan
  • Start date Start date May 2, 2009
W
wakeboardan
611
San Diego
May 2, 2009
  • May 2, 2009
I've got a 68 coupe with a 289 and some long tube headers. Does anybody with a similar setup have pictures of how you may have routed your power steering hoses to keep them away from the headers? Mine run right next to the drivers side header during a tight left turn and im trying to avoid some sort of potential flammability between hot headers and p/s fluid.
2+2GT
3,333
10
79
Southeastern Pennsylvania
May 2, 2009
  • May 2, 2009
You'll need to replace the pressure and return hoses with the GT350 type, which are routed big-block style below the motor mount. You'll also need the bracket that goes down there. You should also weld the steering cylinder drop bracket to the frame, that longer style tends to pull the bolts out by the roots.
W
wakeboardan
611
San Diego
May 2, 2009
  • May 2, 2009
Alright, I went to NAPA tonight and they claim that my c-code 289 has a 52 3/8" length pressure hose, and something for a big block was under 2 feet. I was somewhat confused. Is this guy lost I don't see how two feet of hose would work on a big block. With that info I figured I was better off routing my 52 3/8" hose over a 2' hose that wont reach.
dcstang67
127
  • May 3, 2009
The hose that is only 2 feet is one of two hoses that go together. Check this out. It is a complete kit of all the hoses you need. Mustangs Unlimited - The Premier Source for Mustang, Shelby and Cougar Parts and Accessories
2+2GT
3,333
10
79
May 3, 2009
  • May 3, 2009
Your NAPA guy missed the part where it said "upper" and "lower". And of course he was focused on his lising, which insisted on certain hoses for a 289, since he knows nothing about Mustangs. You need the "GT350" items. That MU picture shows ALL the hoses, and of course you don't need the cylinder hoses. You will need the lower bracket, though. Any good Mustang supplier, such as Glazier's, will have have this stuff.
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Turbo header Starter wire routing?
  • 387lx
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 3, 2026
387lx
P
1964.5 289 Convertible - power steering hose routing bracket question
  • planters49
  • Nov 1, 2024
Classic Mustang Specific Tech Mar 6, 2025
manicmechanic007
I
Hooker Long tubes with Mustang 2 suspension.
  • inetwebguy
  • Jun 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Jun 13, 2024
inetwebguy
I
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
