Im having the same issue, only I tried as hard as I could to push the threaded connector back on the hard line and It wouldnt go back even far enough for me to see the o ring or groove for the o ring what so ever. Also why do you need to remove the whole rack to just put on a pressure line. And even so why not just replace the O ring if you can get the fitting to slide back enough?
