Power steering pump leaking....
they're PRONE to leaking from the pressure line. lol. usually the o-ring goes out. also, over time the return line will start to crack and that can be the culprit. other than that, if too much pressure builds up they can overflow a bit from the cap. as far as what's involved in replacing one, you have to remove the a/c compressor and bracket, fan and shroud. you'll have to use your old pulley and bracket so you'll need a power steering pulley puller to get both the pulleyand bracket off your old pump.
The return hoses are all low pressure and are most commonly secured to the pump and associated plumbing with worm gear hose clamps. After a while they will frequently soften up at the end where they are clamped, and should be replaced. The auto parts store will sell you hose by the foot and it takes about 3 feet or less, depending if you have the fluid cooler in the low pressure side of the line.
Each hose uses an O ring on each end to seal them. The hoses will swivel when they are installed and tightened into place. That is why there are O rings on the fittings. The O ring is the part that actually makes the pressure seal. If you slide the nut all the way back as far as it will go, you will see the O ring and the groove cut into the center section of the fitting.
attachment.php
Sometimes you will get some white Teflon rings with the pump or rack. The rings go on the threaded part of the fitting to reduce or prevent small leaks. They are not meant to seal the pressure part of the line or substitute for the rubber O ring. Heat the white Teflon seals in hot water and they will be easier to install. You can install the fittings without them and not have any leaks if the O rings seal good.
You may find it is easier to drop the rack down to get to the hose fittings. The flex coupling for the steering shaft needs to be disconnected before you can get the rack out. You should disassemble the coupling by undoing the 2 bolts that hold it together.
Remove the two bolts that bolt the rack assembly to the frame and then pull the rack down. Get a catch pan to dump the fluid in when you disconnect the hydraulic lines. I replaced the rack mount bushings with some Energy Suspension urethane ones. When you re-install the rack assembly, put the rear bushings in the rack assembly and lift it into place. Then install the front bushings & washers and tighten down the nuts. Doing it this way makes room for the hydraulic lines without having them bind against the frame.
They will also leak where the high pressure fitting goes into the tank. There are 2 O rings on that fitting and they are super easy to change. Just remove the fitting, remove the old O rings, clean it up, put the new O rings on it and reinstall it. Torque it to 30 ft lbs.
I just replaced all of the seals in my pump. They're not that hard to do. You can also get a chance to see if anything needs replacing inside of the pump.
Thanks guys.
I'll be trying the leaking hose first.
It's not coming from the rack. It also looks like it could be coming from behind the pulley.
Are there any seals in this area?
Yes, there is a shaft seal. With care it could be removed without disassembling the pump. Just try not to nick up the shaft when removing the old one. There is a metal seal retainer that's pops right off and then the seal.
