power steering pump question
With a pulley removal tool, which can be loaned from the parts store. I would get an install tool while at it.
Good luck.
Does the pulley slide on the pump's shaft, or is the shaft actually going in and out of the pump? If the latter, a little bit is normal. If the former, that aint right at all. I would get a new pulley if you are renewing the pump.
Good luck.
