Power steering pump removal?
Guero
2,148
Is there any way I can remove my power steering pump without having to to replace my rack and pinion into a manual one? Like just plug the two holes on the rack? Or Do I have to suck it up? lol!
Yeah, that would be a no. The stock steering shaft is not designed to handle the load of the steering rack without power assist. The steering rack is the wrong ratio, which will not give you enough steering wheel authority to control it properly. And the power steering rack is designed to have a continuous flow of fluid through it. If the flow isn't there, it can cause the steering rack to seize quite suddenly.
Kurt
