  • SN95 4.6L Mustang Tech
Power steering pump replacement
  • Thread starter Thread starter Galadrium
  • Start date Start date Jun 11, 2010
Galadrium
50
Cincinnati, OH
Jun 11, 2010
  • Jun 11, 2010
Power steering fluid has been slowly leaking over the past few years on my 01 GT. Went to Ford today and they quoted me $429 to replace the power steering pump. So now I've elected to do it myself.
I have a Haynes manual. Any advice on making this go smoothly? This is the first power steering pump I've attempted myself.
Thanks in advance.
Rickyll7
718
  • Jun 11, 2010
Does the new pump come with the pulley installed? If not, you will need both the pulley removal and installation tools. They are specific for the PS pump.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 11, 2010
  • Jun 11, 2010
Do not attempt this job without access to the special tools to remove and install (separate tool) the PS pump pulley. Don't even think about even tapping the pulley onto the shaft.
If you rent or buy the tools, double check they are the correct metric thread used in your MY. I had some difficulty finding the correct tool. The SAE tool will appear to work but will stop after a few turns. If used, there are not enough threads engaged and it will strip.
Suggest performing a through inspection. Look to see that the leak is not from the power steering pressure lines at the swivel connections.
With the correct tools, the job is not all that hard. Expect to tired forearms removing the pulley (same to install). Be sure to lub the tool before use.
Recommend getting extra telflon washers. Do not re-use. Heat the washers in a pan of hot water. Use the tappered end of a socket extension to expand the washer to fit over the connector threads. The washer will shrink back after cooling.
I have found that if on initial re-filling, if a power drill is used to slowly spin the pump (belt off), the bleeding process is easier. The center shaft will accept an Allen style bit. Stop spinning when any bubbles are seen. Repeat until no bubbles.
Upon initial start-up, shut the car off if a lot of bubbles are seen. Continued operation will spread ever smaller bubbles through out the system thus making bleeding harder.
Good luck.
Reactions: calmlikeabomb
Galadrium
50
Cincinnati, OH
Jun 12, 2010
  • Jun 12, 2010
Just wanted to report that I started and completed the installation today. Thanks to wmburns for walking me through the job better than the Haynes manual.
After buying the pump and a quart of ATF, the whole thing cost me less than $60.
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
A
Engine 99 V6 Steering Pump Replacement
  • abs68206
  • May 23, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2025
abs68206
A
