Power steering pump squeal!!
  • Thread starter Thread starter 1of4Horsemen
  • Start date Start date Sep 6, 2010
1of4Horsemen
  • Sep 6, 2010
So I have a 69 Fastback with a Mustang II front suspension. Everything seems to work nicely but when turn the wheel all the way left or right the pump squeals like a pig! Is there some sort adjustment I am missing? (the PS pump is a saginaw type)
2+2GT
3,333
10
79
Southeastern Pennsylvania
Sep 6, 2010
  • Sep 6, 2010
Squeal when holding the steering against the stops is normal. You are forcing the pump to hold the steering arms against the stops at 800-1000 p.s.i. and the drive belt can't take the strain. Ease up. It's not like all that force is helping you turn.
1of4Horsemen
  • Sep 6, 2010
Thanks... I only have this problem when I am moving in and out of the garage and such. When I get the squeal I also get PS fluid leaking. Isn't there some sort of pressure relief valve that should shunt off the pressure if it gets too high?
2+2GT
3,333
10
79
Sep 6, 2010
  • Sep 6, 2010
Yeah, but that's inside the pump. When you jam the steering against the stops, the power cylinder spikes to full pressure. Just back off zillionth of an inch when you hit the stop, and your steering parts will last a lot longer.
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
C2 Power Steering pump with Saginaw internals?
  • Mustang5L5
  • Dec 11, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 17, 2024
AeroCoupe
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
