Power Steering Question
  • Thread starter Thread starter 65and68Stang
  • Start date Start date Apr 5, 2004
65and68Stang
148
Raleigh, NC
Apr 5, 2004
  • Apr 5, 2004
Hey guys,
Will a new 5.0 style power steering pump produce too much pressure for a stock (but new) '68 power steering line? Should there be a pressure-relief valve anywhere on the system, or is there even such an animal?
One of my hoses blew apart at the coupling the other night and I'm just wondering if it is a bad hose or too much pressure from the new pump.
Thanks!
Kelton
MustangPaul
514
South East Louisiana
Apr 5, 2004
  • Apr 5, 2004
Which hose?
65--which hose? I had trouble with cylinder hoses--the two small ones on the bottom of the system. Most places have them at the same length, however, I was able to find one place that had one hose .5 inches longer. That saved my couplings.
Still, I'm amazed at what a bad design the PS system is.
--Paul
R
Ronstang
1,294
Houston Texas
Apr 5, 2004
  • Apr 5, 2004
The newer pump is not the problem as it is valved to produce approximately the same max pressure as the earlier pump, from what I have been able to determine. It has been quite a while but I spoke to a Ford engineer about this issue and he assured me the newer pump would work fine.
meweehaa
202
Northeast PA
Apr 5, 2004
  • Apr 5, 2004
Do the pumps mount up the same? My pump is old and ugly and I was thinking about getting a newer one so it would pretty up the engine compartment.
65and68Stang
148
Raleigh, NC
Apr 5, 2004
  • Apr 5, 2004
Thanks Ronstang...I'm thinking (hoping) it was just a bad hose.
Meweehaa, Im not sure...the pump came on my car when I got it. I will try to get a picture of how it is mounted for you though if you'd like?
Thanks!
Kelton
meweehaa
202
Northeast PA
Apr 5, 2004
  • Apr 5, 2004
What year 302 is it? What is it in? Any and all info would be good. I would appreciate the pics as well. Thank you very much. David
65and68Stang
148
Raleigh, NC
Apr 6, 2004
  • Apr 6, 2004
David,
It is a 351W in a '68 Fastback. I will try and shoot a couple of pictures this week for you.
C'ya!
Kelton
meweehaa
202
Northeast PA
Apr 6, 2004
  • Apr 6, 2004
Thanks again.
David
65and68Stang
148
Raleigh, NC
Apr 11, 2004
  • Apr 11, 2004
Pictures as promised!
C'ya!
Kelton
ps - turns out it was a poorly crimped DIY hose...replaced with a correct replacement part and everything is A-OK.
1965 Mustang with 80s 5.0 engine in it Power Steering hose or connection ID?
  • spearce
  • May 19, 2026
Classic Mustang Specific Tech Jun 8, 2026
AeroCoupe
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
F
Power Steering Pump
  • Fri Guy
  • Apr 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 29, 2026
Fri Guy
F
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
