  • SN95 4.6L Mustang Tech
Power Steering Rack Removal Issues.....
  • Thread starter Thread starter SRT Handz
  • Start date Start date Jun 24, 2007
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Jun 24, 2007
  • Jun 24, 2007
I am trying Remove my Front control Arms to replace them but i cannot remove the front Control Arm-to-K-member bolt because the power steering rack is in the way. I removed the 2 bolts holding the steering rack to the K-Member but it still wont pull forward....what do i need to do to make the rack move forward. I have taken the bolt almost all the way out but the steering rack is blocking its way comming out. Is something else holding the rack on? Do i need to remove the hoses to the power steering pump?
...help....
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 24, 2007
  • Jun 24, 2007
there are hollow studs that the rack rests on. i have 2 2 foot prybars that i wedge inbetween the k-member and the rack and pull then and pull the rack off. the studs are about the same length as the rack bolts.
cooper58d2002
98
Hope Mills NC
Jun 24, 2007
  • Jun 24, 2007
did you disconnect the steering shaft from the rack i had to when i replaced the bushings on my rack. then it pulled out no problems its i think a 8 or 10 mm bolt that connects the shaft to the rack right before the rag joint.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jun 24, 2007
  • Jun 24, 2007
Yeah, you have to disconnect the steering shaft.
Do not fully remove the clamp bolt that holds the steering shaft... Just loosen it.
Now would be a great time to install new rack bushings or at least lube the stock ones.
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
Jun 24, 2007
  • Jun 24, 2007
I removed the bolt that connects to the steering shaft to the steering rack but it still wont brake free. I know that the steering is the reason it wont come off because it comes off on the passenger side just fine...but not the drivers side.
...should i just pry at steering rack till it comes off because there is no bolts holding it on.
..and what should i lube the steering rack bushings with?
A
American_Muscle
189
  • Jun 24, 2007
Yeah those rubber bushings that are (I believe) between the rack and pinion and k-member can be like glue.
I took a big screwdriver and wedged it out.
It take a bit of muscle to get it off.
Be sure to tie the rack with zipties to the swaybar so it won't drop down when you do release it.
cooper58d2002
98
Hope Mills NC
Jun 24, 2007
  • Jun 24, 2007
also be care full when your putting that bolt back in on the steering shaft as they strip very easy if you torque it to the right spec you should be fine.
hvcobra99
83
Plymouth MI.
Apr 21, 2008
  • Apr 21, 2008
99 cobra convertible
I noticed a leak comming steering rack looks like a crack in the boot on the drivers side? My question is what can be done about it
W
Will Smith
191
Cape Coral, FL
Apr 22, 2008
  • Apr 22, 2008
the leak your pointing out in the outter seal on that side... normally when that happens the only solution is to replace the rack itself...
hvcobra99
83
Plymouth MI.
Apr 22, 2008
#10
  • Apr 22, 2008
  • #10
steering rack
:SNSign: should I go with a stock one or should I take advantage of the situation and maybe upgrade to a better one and which one do you recommend?
W
Will Smith
191
Cape Coral, FL
Apr 22, 2008
#11
  • Apr 22, 2008
  • #11
the stock racks are ok to replace it with.... if you wanted to switch to a manual rack from flaming river that is a possiblity. your would love the weight of the power assisted rack, power steering pump and lines. but steering will be more difficult.
Superhereaux
chicks make me feel inadequate
538
South Texas
Apr 22, 2008
#12
  • Apr 22, 2008
  • #12
i needed to remove the control arms this past weekend to install Steeda balljoints and just pryed the ****er up and out of the way (not recommended)
kind of a bitch so actually loosening the steering shaft and pulling the rack all the way out is probably your best bet
hvcobra99
83
Plymouth MI.
Apr 22, 2008
#13
  • Apr 22, 2008
  • #13
steering rack
I removed my controll arms front rear but I should of read up on more how to's because I tore the tire rod boot and oil powersterring oil poured out. Luckily ford sells just the boot to replace it for $45.00 Since iam remove the steering rack and shaft Iam going to install Bassani ceramic coated equal length headers . Iam also got the MM IRS grip box and upgrading all bushings to delrin.
My other question is I have never done headers before can I drop the k member by using floor jack and another to hold up motor?
R
rugster
156
#14
  • Apr 22, 2008
  • #14
SRT, take a crowbar and pry the steering connector piece off the shaft. It may take some force but you wont hurt anything. Then the rack should slide right off the 2 posts of the K member in the forward direction. Lube those up before you slide it back on and you should be good to go.
R
Suspension Bushings for SN95 Steering Rack with UPR K Member
  • Riley Barth
  • Jun 23, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
G
79 steering rack problems
  • garyrc
  • Mar 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 8, 2026
AeroCoupe
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
