Power Steering Removal?
Kdubslugga
1,515
Akron, OH
Ive got all the bolts out, only thing left is that rubber hose with a metal fitting on it, looks to be the main feed line. Do i need one of those special fuel line removal tools for it? Hopefully this makes sense to you guys!
yep, i cant think of exactly which line you are referring to (on the pump or rack?) but as i recall, no special line wrenches or anything are needed. nice tight fitting box end should work for ya.
good luck.
No special tools needed. Are you putting in a manual rack? If you are planning to just run the power rack without the pump it is gonna be a pITA to drive and will end up probably destroying the rack since it was intended to be hydralicly operated.
