Power Steering Squealing
  • Thread starter Thread starter wild70stang
  • Start date Start date May 24, 2007
wild70stang
317
  • May 24, 2007
I replaced my power steering pump about a month ago, and it is still making this wierd wurring noise when the engine is at idle, and gets a notch louder when I turn the wheel in either direction. There are no kinked hoses, they are in their proper positions, and it is not leaking. I took it to a shop when I had to have my carburetor cleaned out an they said that it just needed top be topped off. Well, the fluid is still above the add line and still makes NOISE . In my chilton book it said something about using ATF fluid, but I wasnt sure so I just bought a gallon of Valvoline Synthetic Power Steering fluid. Any help is greatly appreciated!!!
Iamdiffrnt
197
South of Detroit, MI
May 24, 2007
  • May 24, 2007
Yeah the power steering takes Type-F atf, don't know if the synthetic you have will help or hinder though.
wild70stang
317
  • May 24, 2007
Thanks. I will drain some of the synthetic out and give it a shot.
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
A
Engine 99 V6 Steering Pump Replacement
  • abs68206
  • May 23, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2025
abs68206
A
90Gt squeal/chirp when hot
  • Bvoss59
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 14, 2025
General karthief
D
Power steering pump bracket with A/C
  • Dczookster
  • Apr 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 2, 2025
rednotch
