power steering ?
manny
590
TAMPA FL
has any one out there taken out the power steering gear and replace it with the manual type? i will be running a 70's series tires up front and yes the car has a v8. thanks in advance.
Yes.
The manual rack has a much better feel.
If you have a tendency to turn the wheel while the cars sitting still you'll get over it real quick.
Yep, Many of us have, because we are Manly Men! :rlaugh: We have a desire to strenghten our arms by yanking on a 13' steering wheel to turn the tires 1 inch. hah ahhah Really though all you do is swap out to a manual rack. The knuckle is slightly different and you do need a manual knuckle. Other than that it's pretty much a straight swap and nets you less maintenance and 1-2 tenths in the 1/4 mile. :nice:
I have 60 series low pros on the front of mine, with the manual R/P. Even after I put on the smaller steering wheel, its not too much effort to turn the wheels. I still dont recommend it while the car is sitting still, but its not the worst thing Ive ever had. Now a 2-ton Dodge truck is a beeoch with the manual steering.:notnice:
I've got 195/60/14s on the front, V8 Auto with a manual rack. It's not too shabbly.
As long as you don't put a mini-spool (like I did) or a tough locker unit in the rear axle, you'll won't notice too much difference. :nice:
I drove my car for years with the power steering belt off cause the pump was really noisy. It wasn' the correct brackets and pump for the car. I had 205/60's on it. Parking lots were some work, but other than that it was fine.
I ditched the power rack for the manual rack. The problem is the stock II manual rack is way too slow!! The lock to lock is like 4 1/2 turns! (guess-ta-ment). I am going to put in either a flamming river rack or a stock power steering rack without a pump back in. I think sleeper put a II power rack in his car with no pump. He just used a P/S jug from some newer car from the wreckers. (many new cars have a jug with two spiggots). The manual rack is safe and works fine, just not very sporty. Also I know the tie rods are different and possibly the rag joint. (I transformed my car 10 something years ago, so the details are getting fuzzy):D The steering effort is not too hard even with the 302. My Lada Niva takes more effort:lol:
Johan said:
I'm in the minority here, I much prefer a power rack. That may not make me as manly, but I much prefer the quicker steering of the power rack - 3 turns lock-to-lock vs 4 turns lock-to-lock.
It's not a question of manliness, the problem is Ford PS are noisy even when new. The manual rack is also smaller diameter than the power version which gives more room when using a non-II oil pan (like my 7-qt deep sump).
