Power Steering???
  • Thread starter Thread starter Georgie
  • Start date Start date Jun 12, 2006
Georgie
455
Montreal, Canada
Jun 12, 2006
  • Jun 12, 2006
OK, igot a new pump for my 5.0. i managed to get the pulley of with a puller, and installed the new pump with old bracket and pulley.. I also have a new pressure hose and return hose... am i supposed to flush the system?? then bleed it????????
HISSIN50
34
129
Jun 12, 2006
  • Jun 12, 2006
It would be smart to flush the system before running that old fluid through your new pump.
You can put the return side line into a bucket and do it that way (accessing the return line where it leaves the PS pipe..er I mean PS cooler, if it's easier - I think so).
Good luck.
Georgie
455
Montreal, Canada
Jun 12, 2006
  • Jun 12, 2006
****...i already installed the new one....i had to scrap the other one..cuz i broke it when i got pissed at the pulley
HISSIN50
34
129
Jun 12, 2006
  • Jun 12, 2006
If you have installed a new pump, you can flush the system without contaminating the new pump. You will remove the return line (it doesnt matter where from the rack to the cooler to the pump that you do this - your choice). You will add fluid to the pump and the new fluid will displace the old fluid into the bucket. The old stuff doesnt go back into the new pump.
Cool?
Georgie
455
Montreal, Canada
Jun 13, 2006
  • Jun 13, 2006
sso i add fluid to the new pump, and it will take the place of the old fluid???do i do this with my new lines or old ones?
Georgie
455
Montreal, Canada
Jun 13, 2006
  • Jun 13, 2006
do i do this with the car on?
HISSIN50
34
129
Jun 13, 2006
  • Jun 13, 2006
I would do a flush with old lines, but it's up to you and what you have done already (I wouldnt worry about it much).
You would be adding fluid to keep the reservoir topped off as the car idles with the return line vented into a bucket. Having an assistant there to shut the car off is nice.
When the fluid coming out of the return line looks clean, you should be getting close to done.
Check your repair manual or the instructions with your pump - both might have some info to help.
Good luck.
Georgie
455
Montreal, Canada
Jun 13, 2006
  • Jun 13, 2006
thanx alot man
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Power steering hoses
  • Teen'93stang5.0
  • Apr 3, 2026
1974 - 1978 Mustang II Talk & Tech Apr 14, 2026
Teen'93stang5.0
