  • 1994 - 1995 Specific Tech
Power Window Gremlin is Back!
  • Thread starter Thread starter Sompin2do
  • Start date Start date May 19, 2007
Sompin2do
59
TX
May 19, 2007
  • May 19, 2007
Had a problem awhile back where my driver side power window wouldn't come down. After checking the motor and finding it good, I shot the wires and those checked out also. Now the problem is back
I can feel and hear the one touch module clicking and the volt gauge on the dash drops. Took a shot in the dark and got a one touch module from ponyperformance.com hoping that was the problem...not so. In the previous episode of the problem I checked the wires with a meter and got correct readings. I'm at complete loss now. Can't find any loose wires, no bare grounds.
Anybody?
Thanks
Mike
Bosko5.0
1,067
longwood, FL
May 20, 2007
  • May 20, 2007
it is most likely the window regulator bushings inside the motor.
my driver side did that last year replaced them and works pefect. my rear window sometimes wont go back up so I thought I would just replace the other 3 windows. so I dont have to do it later.
http://www.latemodelrestoration.com/iwwida.pvx?;item?item_no=LRS-WLK52 1&comp=LRS
Sompin2do
59
TX
May 21, 2007
  • May 21, 2007
I checked the bushings a few months ago when this happened the first time and they were only slightly out of shape. Does your car have the one touch down module?
I even jumped the window motor across the battery and it worked. Weird part is when I put it all back together the window worked, but I never replaced anything.
Bosko5.0
1,067
longwood, FL
May 21, 2007
  • May 21, 2007
I have the one touch module only for the drivers door, if they were slightly out of shape maybe they rotated so that it locked the motor.
Bosko5.0
1,067
longwood, FL
May 22, 2007
  • May 22, 2007
My rear window stopped working today before work. So I took apart sanded the electrical bushing some so they were shiny, then put back together and it worked,
juiced_94gt
1,143
Southern California
May 22, 2007
  • May 22, 2007
i have to press my button on the drivers side like 30 times for it to come down all the way, but i will go up just fine, i replaced the switches, and the bushings inside...any idea what it could be??
Sompin2do
59
TX
May 29, 2007
  • May 29, 2007
Shazam! I replaced the bushings and that did it! I guess when I opened up the motor the first time I didn't really know what good bushing looked like. All 3 of mine were flat on one side. THANKS for the help!
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
J
Thanks for the information on codes 31,34,44 and 94!
  • JK86LX50
  • Mar 5, 2025
  • The Welcome Wagon
The Welcome Wagon Aug 5, 2025
gkomo
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
