Power window help
/\ Vader /\
65
Hey guys, the switch on the drivers side will not lower the passenger window.
The passenger window switch on the passenger door works fine.
I replaced the drivers window switch (passenger side) still no worky.
Any suggestions ?
Thanks 95 Mustang GT Aode (Coupe)
mine was the exact same way......then my motor went out all together.....i am going to replace it tommorrow and see what happens.....i thought it was probably my switch too,but i never got around to replacing it...i will let you know what happens tommorrow after i change out the motor whether it still works or not...you might have a loose wire somewhere that is causing a bad connection...
ok, ill try my hand at this one. Right now Im looking at the wiring schematic on page 12-35 of the Haynes manual (left picture).
1. Make sure you have 0 volts on the ground (black) wire
2. Second, compare the voltage from the yellow wire to the tan/light blue wire. they should be within each other
3. Now, do the same with teh White/black wire and the white/yellow wire
Its obvious that the switch is getting some power due to your driver side windows working. my guess is you have either a bad ground or a bad wire. good luck
